Old 11-30-2017, 08:58 AM   #1
Where is the 12 volt relay for the water heater?
I have no AC at the water heater. Gas works properly. The switch is on and lit in the control panel inside the RV. Drawings indicate a 12 volt relay. Is it part of the power supply?
The Hoser is offline   Reply With Quote
Old 11-30-2017, 08:59 AM   #2
2013 Sabre 33rets
Old 11-30-2017, 09:03 AM   #3
Check to see if the wh is actually plugged into 110 outlet. Also check the breaker inside the electrical panel and the reset button on the wh itself.
Old 11-30-2017, 09:14 AM   #4
I don't believe it's part of the board.
All references I've read has mentioned this relay is usually located near the control panel switch, although I thought I read somewhere that someone found it behind the refer.
Here is one such link I saved a while back.
Read page 8.
Suburban Water Heater Troubleshooting
Days Camped: '16=46 '17=30 '18=51 '19=32
Old 11-30-2017, 11:35 AM   #5
Was working for 4 years. Need to find relay. Typical design for this junk. Guess Iíll start tearing things apart. I can see the AC heading toward the breaker panel but itís such a poor installation itís just a rats nest of wires. Wary of mixing things up and starting more problems.
Old 11-30-2017, 11:40 AM   #6
10 minutes with a multimeter will probably give you some good indications where to start.
Old 11-30-2017, 11:44 AM   #7
I know.. must physically locate the 12 volt relay
Old 11-30-2017, 12:01 PM   #8
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I don't know what water heater you have but I would pull the electric element and check it for continuity before anything else.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 11-30-2017, 01:04 PM   #9
wmtire's Avatar
What is the exact make/model of your water heater and I can provide assistance?
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 11-30-2017, 01:07 PM   #10
Trouble shooting with meter indicates 12 volt relay contacts are open. No AC coming into water heater.
12 volt, heater, water, water heater
