Old 10-26-2011, 06:59 AM   #1
Where is the valve to drain main water tank?
I have a 2010 sv234t ,the underside of trailer is covered,there is 3 tubes coming out of the bottom of trailer 2 are the WH,1 has a blue male hose connection. I can't find valve to drain water tank.
sv234t is offline   Reply With Quote
Old 10-26-2011, 07:07 AM   #2
TURBS's Avatar
Those tubes don't drain your water heater. Most likely your low point drains.
Your hw heater is drained right at you water heater there's a plug at the bottom .
Old 10-26-2011, 07:07 AM   #3
MtnGuy's Avatar
Most water heaters do not have bottom drains. What leads you to believe that 2 of those tubes are bottom drains for the water heater ??
Most likely, the 3 tubes are for your water lines (blue-cold water, red-hot water), and the 3rd tube would be the fresh water tank. Check out the vicinity of the fresh water tank fill, see which way the fill tube heads, and most likely the fresh water tank is in that area.
BTW, welcome to the forum !!!
Old 10-26-2011, 07:08 AM   #4
MtnGuy's Avatar
f1100turbo, you beat me to a response.
Old 10-26-2011, 07:10 AM   #5
TURBS's Avatar
Sorry mtnguy!
That third hose may be an overflow as well?
Old 10-26-2011, 06:45 PM   #6
After going back and looking more closely ,The 2 hoses together are the outside shower,the blue male connection is the main drain,cap is off of it. Thanks for the help.
