03-24-2017, 01:58 PM
Where to buy filter?
I've read a lot of posts about replacing the filter and about removing it and using an external filter. My question is much more elementary: This is my first spring and first time needing to buy a replacement filter, so where do I find the filter replacement? Online? Store? Local Camping World didn't know anything about it. I may remove it later, but going on a trip in a couple of weeks so, short term, I just need to put in a fresh filter. Thanks!
03-24-2017, 04:13 PM
what filter? what model rv? if it is the forest river proprietary fr1 / kw1 I found the best source to be any online vendor. many rv stores do not carry it. I tried to get one from a forest river dealer once and even they did not stock it. it would take two weeks for them to get one. I ordered online and had it in couple of days at less cost than the dealer.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
03-24-2017, 04:19 PM
After searching and searching, i found one online for $50. I removed it.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
03-24-2017, 09:59 PM
Sorry, yes the FR1/KW1. I'll look online.
03-24-2017, 10:01 PM
I guess charcoal made from coconut husks is expensive, bshort. I'll get one for this year and plan to remove it when I winterize this fall.
Thanks for your help.
03-24-2017, 10:27 PM
Ya frightened me. Went to Wally World today looking for that filter. Of course, no luck. But the 1st place I looked online, it was $30 & free shipping.
The Water Pur Company KW1 10-inch Water Filter - New Forest River RV Water Filter | Hanna Trailer Supply Oak Creek, Wisconsin
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
03-24-2017, 10:35 PM
Exact replacements are sold at the WaterPur Company online.
http://www.waterpur.com/html/waterpur_filters.html
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
03-24-2017, 11:04 PM
Canadian Member
I buy mine from the RV Water Filter Store.
03-25-2017, 07:59 AM
one thing I should have mentioned. they also make a wrench to remove and reinstall the clear plastic filter housing. I think it was $8.00. it makes removing the housing very easy. I know there have been many posts about difficulty in removing the housing but I have had no problems when using the wrench.
03-25-2017, 09:23 AM
Ordered one from Water Pur today. Thanks for everyone's help!
RevKen
03-25-2017, 01:40 PM
Water Filter Wrench
Neither of the posts I saw from you mentioned who "they" are. I'm interested in the wrench. Please post supplier's name.
03-25-2017, 01:51 PM
Yes, and it is much easier with the pressure off of the system. Turn off the source and open the faucet until all pressure is released.
03-25-2017, 02:44 PM
i found it online at water pur. $5.00 plus $2.75 shipping. make sure you get the one for the kw1 / fr1 as they have others for sale also. this really does make opening the canister easier.
03-25-2017, 04:49 PM
water filters
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
03-25-2017, 05:37 PM
FILTER
I buy mine at Lowes.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2022 51 DAYS
[SIGPIC][/SI[SIGPIC]
03-26-2017, 09:15 AM
If you have the CC!-10 filter as we do,,, you can buy Charcoal Filters @ Wally World,,,
2 for $10 !!! Filter for taste & sediment only !!!
03-26-2017, 09:27 AM
Camping World does have them, go to the service department not the retail store side. Right around $40, replace ours every spring.
03-26-2017, 09:31 AM
I was told years ago by an Dealer that you could soak them in a weak bleach & water solution,,, and then reuse ?????????????????????????????????????????????????? ???????
03-26-2017, 09:52 AM
Rivnut
Aviator Electra water filter
I found that removing the water filter plastic jar, is to put block wood unter it and pry up gently, this unlocks the teeth in the upper part, then use the wrench to remove the plastic jar with filter.
03-26-2017, 10:39 AM
When we bought our camper I replaced our water filter.
I went to Home Depot and got a whole house water filter with a shut off and bypass.
The water filter that came with the camper made the water pressure really low when working from the pump. I know that it doesn't filter when in bypass but I now use the old filter from the camper with the hose when filling up the water tank.
Sometimes when I hook up in a campground that the water is not really that good I will hook up both filters. I made a stand for the one outside the camper and use the one that is in the camper. Sometimes I'm glad that I do. I can tell from the filter that both of them were stained and have done their job.
