Originally Posted by rac54
I had a somewhat similar situation with the outside shower header assembly on my old Sprinter years ago & ended-up "coating" the crack with JB Weld. It was still holding when I traded the trailer.
X2...I have also used a good 2 part epoxy glue or fiberglass resin. If you can wrap a bit of fiberglass around the outside it will actually be stronger than it was originally.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
