10-06-2015, 02:20 PM
#21
The low point drains have nothing to do with holding tanks. They are there as the lowest point in your potable water system for water to drain by gravity for winterization.
Bruce
10-06-2015, 02:26 PM
#22
Old Ram Guy
So if I get my potable water from the fresh water supply at the camp ground why do I need a low point drain? I'm no plumber or expert but it doesn't make much sense to me to have a low point drain on a system that is completely piped.
Marty, Jenice and DD
2019 Entegra Odyssey 29V
10-06-2015, 02:30 PM
#23
I am a plumber. Your water lines (all of them) fill with water when you hookup to the camp ground supply and without low point drains, you have no way of completely draining the system. But if you have no low point drains and you fill your system with antifreeze, you have nothing to worry about. The point is, if you do have low point drains, you do have to drain them and/or fill them with antifreeze.
Bruce
10-06-2015, 02:32 PM
#24
Old Ram Guy
I'll stick to what I know though - I KNOW I have no low point drains on my park model home and I KNOW it has no holding tanks.
10-06-2015, 02:34 PM
#25
Left Coast
I really think most park models are hard plumbed to supply line, and have no need for tanks. Sewers also hard plumbed. How does fresh water enter?
10-06-2015, 02:36 PM
#26
Since you know this for sure, you have nothing to worry about. Just winterize your unit with antifreeze and you will have no problems.
The OP's dilemma is, he isn't sure if he has them or not.
Bruce
#27
Old Ram Guy
That was my thinking too before I was bombed with expertise. I would still make the call to make sure though.
10-06-2015, 02:38 PM
#28
Old Ram Guy
Originally Posted by nomad297
Since you know this for sure, you have nothing to worry about. Just winterized your unit with antifreeze and you will have no problems.
Bruce
Bruce
Which is why I recommended that he call to find out. I understood the problem, but thanks for the translation.
#29
The 2015 park model at the site next to my seasonal site has two black tanks and two gray tanks. I don't know if they have low point drains, though.
Bruce
10-06-2015, 02:45 PM
#30
Left Coast
Then they have drainable hook-ups. Fresh water is a different story. How does your unit get fresh water...hose?
10-06-2015, 02:47 PM
#31
My unit is just a regular travel trailer and I hookup with a hose. The park model next to me also hooks up with a hose. Is this what you are asking?
Bruce
10-06-2015, 02:48 PM
#32
Does anyone have a suggestion who I should call at Forest River to find out if it has them? I doubt the dealership I bought it from would even know and the call would result in lengthy confusion, if past experience is a good predictor.
10-06-2015, 02:51 PM
#33
Left Coast
Yes.....do you have a battery powered water pump or just need to hook up hose for water?
10-06-2015, 02:57 PM
#34
Left Coast
If you just have to hook a hose up, you'll need some way to push antifreeze thru lines from hose hook up...like an external pump. Then just open 1item at a time and wait for pink stuff, or blow system dry with air.
10-06-2015, 02:58 PM
#35
Misunderstood Bob's post, so I deleted mine here.
Bruce
10-06-2015, 03:01 PM
#36
OK, I have just talked to the guy who answered the service dept. phone at the dealership where I bought it. He told me that if it does not have a fresh water holding tank ( which it doesn't) then it will not have low point drains. Hopefully he is knowledgeable and my question is answered.
If anyone reading this has a trailer WITHOUT a fresh water holding tank that DOES HAVE low point drains, please let me know.
10-06-2015, 03:05 PM
#37
Here are all the phone #'s for FR products, find your division and call.
Coachmen M/H
Concord
2018 / 300 DSC
