05-21-2016, 11:12 AM
#41
Rhinoflex will NOT fit in my bumper. The connecters are over 4" and will not fit.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
05-21-2016, 01:26 PM
#42
Are you sure? My Flagstaff had a 4" square bumper and they fit. You have to rotate the fittings to align the "tabs" on the connectors with the corners of the bumper tube and then it slides right in.
2016 Coachmen Pursuit 31BD
2015 Jeep Wrangler Sport Toad
Nights camped in 2019: 76
05-21-2016, 01:29 PM
#43
2015 GMC Denali HD
05-21-2016, 01:32 PM
#44
Exactly what I had to do. Fit like a glove.
Sent from my SM-G900V using Tapatalk
2016 Cherokee 274DBH
2015 Ford Expedition Limited
2015 Polaris RZR 570 LE Trail Edition
2012 Polaris Sportsman 500
2009 Yamaha Yz250f
05-21-2016, 02:54 PM
#45
Yep, rotate and slide right in a 4" bumper. These instructions were on the original packaging mine came in.
05-21-2016, 03:25 PM
#46
Really? Who reads instructions? Woulda saved me some frustration if I had, I guess...
05-21-2016, 08:23 PM
#47
Professional Curmudgeon
Yes, it will fit that way, but not with anything attached - not even another hose. If I'm not mistaken the OP wanted to stow his hose with fittings attached. I'd like to do the same thing. I'll be ordering a few of those pre manufactured tubes for both my TT's.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
05-21-2016, 08:42 PM
#48
You're exactly right! We all know REAL men don't read instructions until ALL ELSE FAILS!
2011 Traverse LT, 3.6L, FWD
05-21-2016, 09:36 PM
#49
But they will. Trust me.
I attach two short hoses together and put caps/plugs on them. The longer hose has a cap and the ell.
It all fits in the 4" bumper.
05-21-2016, 09:42 PM
#50
Again, I 2nd that. It will fit.
2009 Yamaha Yz250f
05-21-2016, 10:15 PM
#51
Two 5" PVC fence post from HD with gutter downspouts cut in half as full length slide out trays and fence post end caps hinged to each end. Lots od room for sewer hoses and fishing poles, etc.
Sorry about the pix being sideways. Spent about $40 on these. Screwed them to the frame using large fender washers and bolts.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
05-21-2016, 10:22 PM
#52
That's what I thought too. I was all ready to make my own tube to mount under and one day I just checked and it DOES fit. I measured the barbs and it was 4.5" but they do go in each corner and it does fit. I have a 15' Rhino in one side and a 10' extension in the other.
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Equilizer WDH
Goodyear Endurance Tires
05-21-2016, 10:44 PM
#53
I have my 15 ft and 10 ft extension stuffed into my bumper. I pull out the 15 ft then disconnect from extension and purge.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
05-22-2016, 08:55 AM
#54
I always use a clear fitting especially on the black tank valve. Sense I can't get my fittings into my bumper as far as I am concerned the only thing the bumper is good for is a mud wasp collector. That is why I use a large tote and slide it in the basement. I can coil my hoses and place my fittings in a tote with no problem.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
05-22-2016, 01:51 PM
#55
Where to put sewer hose
I feel your pain. I had the same problem. Went to Lowes. Look in the vinyl fence area. They have a two square post that fit over normal post that you would sink into ground. Get the larger, I think 5" square. Cost about $25. Get 4 stainless steel adjustable bands 7-8 size over in plumbing. About $2-$3 each. Using bands attach to side of rear ladder. Drill hole all the way through the vinyl post at bottom and place bolt with lock nut. I can insert two sections of sewer hose, 90 connector, 180 connector and 45 connector all up through the bottom then insert the bolt so the won't fall out. When ready, remove bolt and pull out hose. Pictures are included.
05-22-2016, 03:08 PM
#56
The Super-Slider looks like a really good product. I used the fence post with the vinyls gutter to hold the hose and fittings. An advantage of using the gutter is it holds any excess moisture that might come from the hose and prevents it from collecting inside the fence post. I assume that after a lot of use there could be a not so nice collection of whatever.
When I get home from a trip I pull the gutter with the hose and rinse them down and completely dry before putting back into the fence post.
I don't think the Super-Slider is big enough to hold a hose secured in a gutter.
BIRDS AREN’T REAL
05-22-2016, 03:21 PM
#57
YES! Finally something large enough to hold a 90 degree fitting along with the hose. And sense it is square it could be bolted on top of the bumper. Then I could paint it black and no one will know the difference.
My doctor said my broken hip is healing well. He wants me to wait two weeks before I put any weight on it so in two weeks I can put my prosthetic on and start walking again, So in two weeks I will be heading for HD for some fence post.
Thank you,
Jim
George Bernard Shaw
