Old 04-19-2015, 06:46 PM   #1
Which of these is by-pass valve?
I'm getting ready to de-winterize our TT. There are these 3 valves all close to each other. I'm assuming one is the shut off for hot, one shut off for cold and the valve on the vertical lines is the by-pass. Am I correct? What would the shut offs for hot and cold be used for? This is our first TT so this is all new to us.
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 04-19-2015, 06:51 PM   #2
The ones going into the tank are to keep antifreeze from going into the tank. When they are closed, the vertical one needs to be open. After you flush the antifreeze out, open the ones going into the tank and close the vertical one.
Old 04-19-2015, 07:31 PM   #3
Name:   Summer Position.jpg
Normal use
Name:   Winter Position.jpg
Bypass for winterizing
