Old 12-07-2018, 11:28 AM   #1
Explore
Camp4two's Avatar
Which Potable Water Transfer Pump for Dry Camping?
I want to pump potable water from my water jugs into my new travel trailer’s 52 gal. water tank when dry camping. There are several 12V and 115V water transfer pumps for sale on Amazon, Harbor Freight, etc. I have a 1000W inverter, two deep cycle 6 volt batteries and a 100W solar panel to recharge batteries
Seems like either a 12V or 115V pump will work with my setup.
-Which type pump (12V/115V) are you using when dry camping?
-Which type pump (12V or 115V plugged into a 1000W inverter) has less drain on deep cycle batteries?
-Any make/model pump you recommend are appreciated.
Camp4two
2019 Rockwood Mini Lite 2511S Mid-year
2014 F150 Lariat 4x4 3.5 EB
Camp4two is offline   Reply With Quote
Old 12-07-2018, 11:46 AM   #2
Hi,
Have you investigated whether your on board pump and existing plumbing can serve that purpose?
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 12-07-2018, 12:16 PM   #3
KeithInUpstateNY's Avatar
I dry camp about five months out of the year in a State Forest. I don't use a pump to fill my tank. I have three six gallon Igloo Cargo water containers. On one of them I adapted the spout with a piece of 18" clear flexible tubing I purchased at Home Depot. The inside diameter of the tubing matches the external diameter of the spout and is held in place with two stainless steel screws. I cut the end of the tubing at an angle to make it easier to insert it in the filler port for the holding tank. You do have to be able to lift about 50 pounds to do this. Be sure to pull the vent plug on the container. I just transfer the adapted nozzle to whichever container I am using, but you could put an adapter on each nozzle.
You want to sanitize your jugs with about a half teaspoon of chlorine bleach on a regular basis, especially in warmer weather, whether you are using a pump, or my method.
As a side note I don't use water from the tank for drinking. I have two three gallon Primo water jugs I bought and fill at Walmart for $.39 a gallon. I upgraded from the manual pump to the electronic pump this year and love it. It recharges via a USB cable: Primo Portable Electronic Water Pump
http://www.walmart.com/ip/Primo-Port...Pump/469103805
KeithInUpstateNY is offline   Reply With Quote
Old 12-07-2018, 12:38 PM   #4
I have a similar set up to the above poster with the angle cut hose that attaches to my Scepter MWC with a water bandit. Lifting the MWC is about 50 pouns at first.
I also have a Shurflo 12 volt volt pump (exact match to the pump in the trailer, think spare parts) that I can connect to the water cans and run a hose to the fill point of the trailer tank for transfer purposes.
I put a “12 V tail” with Anderson connectors that hangs outside the front battery box to power stuff including the portable pump. It can plug inwith enough wire length to place the cans and pump at the tank fill point.
ID:	192777   Click image for larger version
Most coincidences appear to be carefully planned
Jeffjeeptj is offline   Reply With Quote
Old 12-07-2018, 01:03 PM   #5
Canadian Member
itat's Avatar
I upgraded the factory 12V water pump to a newer, quieter Shurflo model and re-purposed the old pump for pumping water out of 6 gallon containers into the FW tank.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 12-07-2018, 01:09 PM   #6
Explore
Camp4two's Avatar
Yes, with modifying the water lines. But I prefer not to go this route using my on board pump.
Old 12-07-2018, 01:20 PM   #7
RACarvalho's Avatar
back from my sailing days:
Try westmarine.com for the pumps.
They have pumps for 1 to 4+ faucets so you can choose how fast you transfer...
I would use the truck 12V outlet for that pump if it can handle the watts...
Ricardo & Luciana Carvalho
2018 F150 XLT V8 HDPP
2018 Rockwood 2909WS
RACarvalho is offline   Reply With Quote
Old 12-07-2018, 04:02 PM   #8
Part-Time
Portable pump
Camp4two
I use this one;
https://www.amazon.com/Rule-IL500PK-...pump+slim+line
I also have a portable jump battery from "Genius" that I use to power the pump amongst many other things. The pump will empty one of those 7 gallon jugs in approx. a minute an half. I bought some additional food safe tubing to go from the pump to the trailer. Works great.
mwtracht is offline   Reply With Quote
Old 12-07-2018, 05:32 PM   #9
Homebrew's Avatar
I’ve repiped my system so I can use my on board pump to move water from my antifreeze suction line into my FW tank by opening and closing some valves.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 12-07-2018, 05:43 PM   #10
I purchased a transfer pump from HD that is powered by my 12V Electric drill (same drill that I use to raise and lower the levelers).
CastleRockcamper is offline   Reply With Quote
camping, dry camping, pump, water
