Old 10-24-2018, 01:00 PM   #1
Why you should always use a regulator on your City Water connection
Would never have guessed this park would have had this much pressure. Rose to over 110 when I first turned on then dropped just before I took picture:
No warning signs in campground office or anywhere in the park.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 10-24-2018, 01:22 PM   #2
Iwannacamp's Avatar
Hello... you must have tapped into the "pressure washer port"
2017 Puma 297RLSS
Old 10-24-2018, 01:24 PM   #3
Good picture. That would not have been good for your water lines.
Happy Camping!
2015 Dynamax REV 24TB class C
2nd rig 2006 Toyota Tundra &
2010 Cikira 21RB 19' travel trailer
Reverse_snowbird is offline   Reply With Quote
Old 10-24-2018, 01:47 PM   #4
Trailer Park Supervisor
NJKris's Avatar
And that my friends, is why they say to always use a pressure regulator. Good to know I did not waste my money on mine.
NJKris is offline   Reply With Quote
Old 10-24-2018, 01:54 PM   #5
NJKris's Avatar
Now, THAT'S a shower!
Old 10-24-2018, 01:56 PM   #6
Multi-Slacker
Street pressure (as opposed to house pressure) here is usually well over 100 psi. Where I used to live, in Alta Loma, street pressure was around 100 - 150. I do not know how to translate water tank elevation to psi, but that's the cause.
2017 Forest River Sonoma 280RKS
2018 Silverado 2500 HD 6.0L, 4:10 rear
Prodigy P3 Brake Controller
Andersen WDH / Class V (2000 lb) Receiver
CurtPutnam is online now   Reply With Quote
Old 10-24-2018, 02:24 PM   #7
So, are the cheap walmart regulators sufficient or should I invest in an adjustable metered one
OKI Marine is offline   Reply With Quote
Old 10-24-2018, 02:35 PM   #8
NJKris's Avatar
I ended up getting the one with a gauge and is adjustable, in case I wanted to play with the pressure. Also, read this under Amazon reviews for the cheap Camco one: Have run a small campground for 50+ years. This type of regulator is highly susceptible to tiny sand or debris in the water lines. A fine screen filter helps but only minimally. Have flushed these in every which way trying to clean - not much luck. If any consolation, junk brass can bring up to $3.00 lb!!
I paid 32 bucks for one with an oil filled gauge on Amazon, I see it is now 28 bucks https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 10-24-2018, 02:43 PM   #9
I have two different regulators. One is a simple brass one with no gauge and the other is adjustable with a gauge. Both work the same for me. Even expensive regulators can malfunction when debris gets into them. For the most part I don't see trash coming from the water line but rather from the hose end should it get dropped on the ground. I make it a habit to open the faucet to clear it of any spiders or other thirsty bugs, then rinse end of regulator before hooking it up. I then run water through the hose to flush it before hooking up to the TT. So far this method has worked well (for over 40 years).
2004 Nissan Titan
Old 10-24-2018, 02:56 PM   #10
NJKris's Avatar
I'm jealous that you've been RVing for 40 years. For me to reach that stage, I'll be 93. But more likely taking a dirt nap.
city water, water, water connection
