Old 02-24-2012, 01:00 PM   #1
Windjammer 3002w
Anyone know where the water filter is located on 2011 3002w Windjammer?
mrores is offline   Reply With Quote
Old 02-24-2012, 04:29 PM   #2
Dave_Monica's Avatar
I don't own a 3002W, but the water filter is usually located close to where the city water connection comes into the camper. It's probably in a lower cabinet behind a removable panel. Your water pump and water heater bypass valves will most likely be in the same location.
Dave
Old 02-24-2012, 04:54 PM   #3
Thanks for the reply. I think I found it by the city water connection behind the outside shower. Looked inside and it should be under the wardrobe closet but the only panel I could find appears to be secured from the inside.
Old 02-24-2012, 06:11 PM   #4
Rebel702's Avatar
Yes, it is in the lower cabinet under the wardrobe closet. Remove the screws in the panel on the left and you will have access to the pump and the filter.
Edit: also to the pump bypass for the outside winterization fitting. I use this also to sanitize the system w/ a 5 gal. bucket & a little bleach.
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 02-24-2012, 06:45 PM   #5
Thanks alot, didn't see any screws on the panel but I look again.
Old 02-24-2012, 07:04 PM   #6
Rebel702's Avatar
Hopefully, they did not install the panel backwards! Mine has a 1/2" blocking on the front with 2 screws going into the floor. If I get out to the TT over the weekend I will shoot you a pic.
EQ-4, 14,000/1,400
2006 Yukon Denali
Old 02-24-2012, 07:07 PM   #7
Rebel702's Avatar
Look at the panel under your kitchen sink from the outside door. The panel to the right is screwed into the floor. Removing this panel gets you access to the water heater bypass controls. This would be similar to what you should see for the water filter panel.
EQ-4, 14,000/1,400
2006 Yukon Denali
Old 02-24-2012, 07:10 PM   #8
Great, thanks again! For info the service tech at the dealer didn't even know where it was!
Old 02-24-2012, 07:19 PM   #9
Rebel702's Avatar
We picked ours up last fall. Our dealer is in Missouri and did a very thorough walk-thru with us. Including a climb on the roof. I had already spent several months on the forums and learned a lot being a new owner. Let me know if you have any other questions. Several "Pointed Nose" owners on the forums so keep posting or searching.
EQ-4, 14,000/1,400
2006 Yukon Denali
Old 02-25-2012, 12:42 AM   #10
I'll do that thanks.
