Old 11-08-2015, 08:28 PM   #1
Windjammer 3008w tank heater
Can anyone tell me exactly what and when you use the tank heater? I'm not sure if it's just for freezing temperatures. I've looked all though my book and nothing mentions what it is for.
dkkirkland is offline   Reply With Quote
Old 11-08-2015, 11:25 PM   #2
ov845's Avatar
Correct. If you're camping and temps happen to drop near or below 32 degrees turn them on.
Happy Camping!
2012 Ram 1500 5.7L 3.92
Airlift 1000
2015 2809W WindJammer
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 11-09-2015, 09:34 AM   #3
D_B Travelers's Avatar
Tank Heat
I believe my manual tells me to turn them on (switch is on control panel) if you expect temps below 40 degrees. They then have a thermostat that will turn the heat on and off as needed to keep them from freezing up. You could probably leave them on if you wanted, but the manual didn't say anything about doing that. Probably better to activate the system only when you know it might be needed than to accidentally risk heating an empty tank and melting something.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 11-09-2015, 11:10 AM   #4
fonzie's Avatar
Here is manual....
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 11-09-2015, 11:22 AM   #5
Yup, same manual as mine. I stand corrected...45 degrees is the low point setting, and they do say it is better to turn them off when not needed.
3008w, heater, tank, windjammer
