I used to own a 5r the mfg. didn't use clamps on flex ducts - the belly heater duct was laying loose near the furnace. I've checked my latest 5r under belly cover with a cheap Harbor Freight IR heat sensor, at least between the main beams its harm enough to prevent frozen pipes. If pipes are freezing what's happening to the holding tanks? Most 3 season TT have mfg. holes in heat ducts to heat between floor and belly cover for tanks and water lines. By the way the other 5r belly cover was 4 inches too short, let out heat but boy did the critters enjoy the comfort - too many problems that 5r is gone.
DJsFolly
