Old 10-29-2017, 02:31 PM   #1
Teamgreen's Avatar
Winterization Warning
Hello;
New to Forums, first time post.
Wife and i purchased a brand new 2018 Forest River Grey Wolf 23MK.
When i went to winterize it I turned the pump on and copious amounts of water began coming out of of the hose . So much so i wondered where it was coming from. Turns out the potable water tank was full!
My wife and i are not boon dockers and we never touched the tank in any way.
Upon researching this forum we think we know what happened. The ball check valve was stuck open in the pump and allowed city water to fill the tank. Had I not intentionally tried to drain all water before adding antifreeze i would have started next season with a cracked potable water tank and would had have to replace it out of pocket.
Also , i checked for a drain underneath the trailer from the bottom of the tank and there is nothing there! The potable hose goes down underneath where the Black tank is and its covered with a black plastic cover and sealed up with lots of foam.
That said my warning is to check the potable water tank for water even if never used.
Maybe that's why the listed dry weight and my scale weight was off by 800 lbs
Thanks for the great site
Teamgreen
Teamgreen is offline   Reply With Quote
Old 10-29-2017, 02:39 PM   #2
asquared's Avatar
It is also possible the selling dealer filled the tank for you.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-29-2017, 03:17 PM   #3
The post before this one I beleive has it right
If the check valve were stuck open letting city water fill the tank (common problem) eventually you would have water spilling from the fresh water filler neck.
I am a systems person and so I always work from the source to the destination. Drain the tank, blow the lines using the city water connection, run the pump until you hear it go up in RPM, watch for spitting water at all the faucets, toilet, outside shower, outside kitchen, etc. Bypass the water heater and then start the RV antifreeze through the whole system until pink comes from all the outlets. Don't forget to pull the anode rod or open the drain on the water heater.
Good post to remind fulltime park campers to check the tank or check something they never used. Thanks for the reminder.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 10-29-2017, 03:30 PM   #4
Novice Travel Trailer Guy
benchmarks's Avatar
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
benchmarks is offline   Reply With Quote
Old 10-29-2017, 03:30 PM   #5
dbledan's Avatar
Good warning. This is why I always have my FW tank valve open if I am not using it. Last campout I saw a slow leak from it in the morning. I had to detach CW and put some water in the tank and charge the pump to get the valve to close fully.
dbledan is offline   Reply With Quote
Old 10-29-2017, 03:31 PM   #6
benchmarks's Avatar
They did on mine....part of testing I presumed.
Old 10-29-2017, 03:38 PM   #7
Hugeez's Avatar
Welcome and congrats on your purchase.
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
9 nights camped so far in 2018
Hugeez is offline   Reply With Quote
Old 10-29-2017, 04:49 PM   #8
benchmarks's Avatar
I think of doing this but I am concerned about bugs getting in. Just do not want any plumbing issues.
Old 10-29-2017, 04:50 PM   #9
Can you please tell me what size of socket to use on the anode rod on the water heater? I need to remove it to drain it. I have a 2018 Salem Hemisphere 300BH
Thank you!
Garymo is offline   Reply With Quote
Old 10-29-2017, 05:04 PM   #10
benchmarks's Avatar
Thank you!
11/16
winter
