Old 11-06-2017, 01:06 PM   #1
campfiregirl57's Avatar
Winterizing
Getting ready to winterize my 282rk Salem Hemisphere. I would like to use a bicycle tire pump to clear the lines. Does anyone know what the attachment is called that connects the pump to my city water connection inlet? I need to know what to ask for at the store. I'm in Tennessee and winter's aren't too bad. Plan on using antifreeze in p traps, toilet only. TIA
campfiregirl57 is offline   Reply With Quote
Old 11-06-2017, 01:17 PM   #2
Here's the two blow out adapters Walmart sells with a tire valve stem...
Blow Out Adapter # 1
Blow out Adapter # 2
Not sure a bicycle/tire pump has enough volume to adequately blow out the plumbing lines for winterization but may be so in your climate.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 11-06-2017, 01:18 PM   #3
marinerjoe's Avatar
You will DEFINITELY get your exercise if you try to use a tire pump. The adapter you would want is a 3/4" garden hose male with a schrader valve.
Using a small compressor took quite a while to blow out the water on my 21FBRS. You may want to rethink your method. A small tire pressure inflator (12v that plugs into a cigarette lighter outlet) would likewise take a LONG time to clear your lines.
Regardless of which way you go, you'll need to make sure you get all the water out. Good luck and let us know what you end up doing.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 11-06-2017, 01:23 PM   #4
Yeah you want about 40 psi blown through the lines, I don't think you'll be able to get that out of a bike pump.
2019 Silverado 1500
No camper, currently
polishdon is offline   Reply With Quote
Old 11-06-2017, 01:31 PM   #5
Who Dares, Wins
doc73's Avatar
Look up the "fit rv" on YouTube. He just did a video on using a tire pump. But his camper is a small winabago travago.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 11-06-2017, 02:26 PM   #6
Yeah, saw it, liked it...that's where I decided. But maybe now no?
Old 11-06-2017, 02:40 PM   #7
Who Dares, Wins
doc73's Avatar
60 psi is 60 psi. But if you are pumping by hand it will get old quick. At 60psi on my home compressor it takes 15 to 20 ml of constant air pressure to make sure that all the lines are blown out.
2015 ChevyHD D-Max
Old 11-07-2017, 11:38 PM   #8
Commercial Member
It's not the pressure that blows out the lines but the volume of the air flow that pushes the water out and doesn't give the water time to flow back.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling)@ FMCA in Tuscon, AZ and Syracuse NY in 2020
Tireman9 is offline   Reply With Quote
Old 11-08-2017, 10:23 AM   #9
Chaplain Kent's Avatar
Plumbing is expensive to repair, why cheap out with preventing an expensive repair? Get a compressor. You will also be able to keep your tries properly inflated extending their life and saving you even more money.
Chummy V
Coachman Freedom Express 192RBS
2000 Ford Excursion 7.3
Chaplain Kent is offline   Reply With Quote
winter
