Old 10-08-2011, 11:08 AM   #1
winterizing
I don't know how to drain the hot water heater on my grey wolf toy hauler. It was not used this summer, bt I want to make sure there is no water in it before it gets too cold. There are no pictures in my manual to refer to - last year I had someone come to service it for winter, but would rather do it myself. I also do not know where the water filter is located to take out before sanitizing the system as directed in the book. Please help! Deb
new 2 this is offline   Reply With Quote
Old 10-08-2011, 11:12 AM   #2
jtstromsburg's Avatar
To drain the water heater, there should be a drain on it. If you open the access panel to the wh, remove the drain plug or anode plug (depending on wether its a suburban or not), & pull on the silver pop off valve handle to allow the water to flow out, if there is any in it. Not sure on the filter, but I think they are usually near the water pump. My trailer doesn't have one so I just use a cheapo in line where I connect my water hose
Help this helps
Joel
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-08-2011, 11:14 AM   #3
going to try - thanks!
