Originally Posted by Lovetoocamp
Hi there, I have a Forest River ePro, 2018. Am trying to winterize...the manual tells me to "fill the tank above minimum water pump operation level with RV antifreeze."
It then tells me to turn the water pump on and open the cold water faucet.
Which "tank" is the manual referring to??
The owners manual is generic and has nothing to do with your particular RV.
NEVER fill your FW tank with antifreeze.
1. It's not needed as long as you drain the tank
2. You would have to use tons of water to flush the taste out
The FW, gray and black tanks have room for liquid expansion when freezing, as long as they are drained.
It's the water lines that don't have room.
