Old 10-19-2014, 09:16 PM   #31
ColoradoRick's Avatar
Yes but it's just to get rid of the rest of the red stuff...they are already full of it from the faucets. One thing I don't do is put any into the fresh water tank because the drain removes it all.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-19-2014, 09:20 PM   #32
I leave everything as-is because in the Spring I will put hot water and a little bleach in a big bucket and de-winterize all the same lines. (Gallons and gallons)
Rick & Karen
Monument, Colorado
Old 10-20-2014, 07:01 AM   #33
BillyBass's Avatar
Do You have to Do the low point drain s i never did before
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 10-20-2014, 07:15 AM   #34
Witch Doctor's Avatar
Once you open them to drain then close them again before you start they will fill automatically. The low point drains are your weak points. They are exposed to the weather. I added two shut off valves inside the basement to them. that will keep water out of the low points. I just open the inside valves to drain them. I had those freeze camping before which caused a leak at the 90 degree fitting on mine and leaked water and filled the underbelly from expanding the clamp connector.Other then that put insulation on the low side drains sticking out the underbelly.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 10-20-2014, 07:17 AM   #35
Yes....if there's water in there and it's a hard freeze, it'll break them to pieces. (I had some water in my copper manifold for my sprinkler system that cracked clean in half...it's amazing!)
I'm a little paranoid about having water in both my fresh water tank drain and in the low point drains and will open them up in the winter to let whatever is in there out. (And there's usually a little bit in there.)
Rick & Karen
Monument, Colorado
Old 10-20-2014, 07:24 PM   #36
Does anyone know what the part # is for a by-pass kit on a Georgetown 351?
tfebb17 is offline   Reply With Quote
Old 10-21-2014, 01:52 AM   #37
Just a member
kandl's Avatar
Originally Posted by HONDAMAN174 View Post
Yes... Blowing out the lines works great for people like us where the temps get below 32 for like three days all winter.
Works great for us too where the temps can reach -40. And when old man winter finally decides to take a hike, there's no de-winterizing. Pressurize the plumbing, leak check and go!
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
winter, winterize
