Old 10-17-2014, 09:32 PM   #1
NOREASTRV's Avatar
Winterizing
I did not have much luck finding detailed instructions for winterizing my TT, the only information I found was to blow out the lines with air, has anyone not blown out their lines with compressed air? Wondering if removing the water filter, opening the drains, then adding AF so the pump draws through system, is there an adapter kit that can be purchased? Any help would be appreciated.
Tom and Julie
2015 Rockwood 2703WS Emerald
2012 GMC Sierra Crew 4x4 1500 SLT Z71
NOREASTRV is offline   Reply With Quote
Old 10-17-2014, 09:38 PM   #2
jtstromsburg's Avatar
Yup, both ways work fine. Remove house filter if applicable, Bypass and Drain water heater and low point lines, tanks etc. Then pump in rv antifreeze and run thru all faucets, toilets, outside showers, etc. Add a little antifreeze to drain traps and you should be good to go.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 10-17-2014, 10:54 PM   #3
ColoradoRick's Avatar
That's correct..you don't have to blow out the lines...the goal is to not having ANY water in places where it can freeze, expand, and break stuff. (Many just do both because we really don't want to discover freeze problems in the Spring!)
I, originally, only wanted to blow out the lines because i didn't want to mess with the strange red stuff....but now I'm thankful that I use the red stuff...it protects to -50 and really isn't all that hard to rinse out in the Spring.
Winterizing really isn't difficult and there's a ton of Youtube videos that walk through many ways of doing it. (Some better than others...I've learned a lot from these channels "Love Your RV" "RV Education 101" and "RV Travel")
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-17-2014, 11:05 PM   #4
HONDAMAN174's Avatar
Yes... Blowing out the lines works great for people like us where the temps get below 32 for like three days all winter. We camp mostly thru "winter" and just blow out the lines when done that weekend just in case the temps drop before we get out again.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 10-18-2014, 08:28 AM   #5
Don't forget to leave a couple inches on pink stuff in the toilet to keep the rubber seal from drying out.
Old 10-18-2014, 08:57 AM   #6
mark0224's Avatar
The only thing that hasn't been talked about is the water heater make sure and change the bypass valves so the pink antifreeze doesn't get in the water heater and remove the anode so it doesn't rust in place. Go to hardware and get a plastic plug to put in where the anode was so threads don't rust. You don't want antifreeze in the water heater I was told it would damage the water heater.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-18-2014, 09:04 AM   #7
TURBS's Avatar
Post 2 says bypass
Turbs
Old 10-18-2014, 09:32 AM   #8
BillyBass's Avatar
I blow out all my lines then I add af. I rather be safe then sorry.I switch my values around and take out my filter and plug to the water tank.I add window washer fluid to my drains.Its cheaper
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
BillyBass is offline   Reply With Quote
Old 10-18-2014, 09:49 AM   #9
NOREASTRV's Avatar
Anyone remember what size socket the water heater drain is ?
Tom and Julie
Old 10-18-2014, 09:53 AM   #10
rattleNsmoke's Avatar
The pink stuff will not damage the water heater if removed immediately. Not sure about leaving it in all winter tho. The anode rod \ heater drain nut size on mine is 1 and 1/16".
rattleNsmoke is offline   Reply With Quote
Old 10-18-2014, 10:04 AM   #11
Ford Idaho's Avatar
1-1/16 inch for the anode.
The plastic plug for Atwood's is 7/8 or 15/16 inch.
Old 10-18-2014, 10:06 AM   #12
NOREASTRV's Avatar
Thanks everyone, one last question, I saw a YouTube video where you get a fitting and hose for the pump to put in the gallons of antifreeze, is this a dealer item?
Tom and Julie
Old 10-18-2014, 10:11 AM   #13
Something like this?
Pump Converter Winterizer Kit - Camco 36543 - Winterizing - Camping World
Old 10-18-2014, 11:54 AM   #14
WFD
Are you sure your trailer doesn't already have winterizing kit installed? Many do...it will be right next to your water pump if you do, unless your trailer is equipped with an outside antifreeze hook up.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-18-2014, 12:27 PM   #15
mark0224's Avatar
Mine didn't have one, got one off amazon
Old 10-18-2014, 12:32 PM   #16
1 inch and 1/16th SAE or 27mm METRIC
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 10-18-2014, 01:40 PM   #17
For the input for the winterization inlet, pick up a hose, clamp, and adapter at Home Depot. Click image for larger version
Name:	ImageUploadedByForest River Forums1413657632.746629.jpg
Rick & Karen
Monument, Colorado
Old 10-18-2014, 05:33 PM   #18
NOREASTRV's Avatar
Thank you for the suggestion about already being set up with it, guess I should have looked !! Click image for larger version
Name:	ImageUploadedByForest River Forums1413671548.689078.jpg
Tom and Julie
Old 10-18-2014, 05:44 PM   #19
Witch Doctor's Avatar
Your all set now, the only thing is that It's to soon to talk about this. I do not know what happened to my camping season...
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-18-2014, 05:56 PM   #20
Ford Idaho's Avatar
Wrong thread, sorry.
winter, winterize
