Old 09-09-2010, 12:48 AM   #1
Winterizing - An Unfortunate Incident
I was winterizing the trailer last weekend (sad but true... summer is over for us ) and using air pressure to blow out the water lines. I gapped out and put the water heater valves in bypass while I still had pressure on the lines.
I was puttering around, ran a bit of antifreeze in the lines etc...I went to drain the water heater about an hour later and as I was removing the anode rod in the heater to drain..I could hear a hiss as I was getting down to the last of the threads...before I knew what was going on...BLAM... It shot the rod out, and six gallons of water in a real hurry, with most of it ending up on me. Thank god I was standing to the side as that rod is about crotch level!
It did a good job of blowing out alot of crud, also I was amazed at how much was chewed off of the anode rod over the summer, as we only used it for about 10 nights this season....next year I am draining the tank after trips.
Also keep in mind there is still alot of water left in the bottom of the water heater, I use a wet & dry vac and a skinny hose to suck up the remaining water. I use the vac also to suck out the traps in the sinks...and replace the water with antifreeze.
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 09-09-2010, 12:58 AM   #2
2Susan's Avatar
Would not have thought to drain the water heater tank after trips. we've used ours many more nights this year so I'm very interested to see what kind of crud comes out of our tank.
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 09-09-2010, 07:13 AM   #3
Now a "Top Member"
EdJunior's Avatar
Wow. First, sorry to hear you have to winterize so early! It hasn't even started to coold down here yet! Second, glad that projectile missed you. Crotch level or not, it could have done some serious damage. Important safety tip there for sure. And, great learning experience for all of us.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 09-09-2010, 07:42 AM   #4
KyDan's Avatar
I unscrewed my anode rod with normal 12v pump pressure on it
and it really does get you wet in a hurry!! It's a memorable
experience so I hope to not repeat it.
A lot of the "crud" in the bottom is actually fallout from the anode.
I know it looks bad but unless it's half gone or more, it's still OK.
I considered removing my anode between trips to drain the tank
but the threads in the tank want to rust so bad that I coat
them and the anode threads with "Oatey great white" teflon pipe
dope and just leave it in there for the summer. Not sure
what the answer is to limiting the rust in the tank threads during
the winter.....
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 09-09-2010, 07:49 AM   #5
Herk7769's Avatar
See my winterizing tale in the "Water Filter...again" thread.
HAM CALLSIGN - KC3FFW
Old 09-09-2010, 11:24 AM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
Open the pressure relief valve first and the water will not blast out. It will still come out and splash on you if you're too close but the anode rod will come out without problems or becoming a projectile. Even though you set it to by-pass the pressure from the last time it was used is still there. As for cleasning it out I take a wand I made to spray out the crud that ends up in the water heater.
Forest River Forums - cfsoistman's Album: Water Heater Cleaning Wand
Just hook it up to your hose and rinse thoroughly.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-09-2010, 04:18 PM   #7
Traveler II's Avatar
I bought a wand at Camping World and use it to spray the crud in the water heater. I will winterize our rig on Saturday. The seasons over for us also.
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair
Nights camped in 2011: 120
Traveler II is offline   Reply With Quote
