10-28-2017, 08:18 PM
Winterizing and Black tank flush
I have searched for a while on here but came up empty. So I’ll have to ask. I winterized today and just wondering if there is anything I need to do to the black tank flush. Trailer is a Gray Wolf 26DBH. Thanks in advance.
10-28-2017, 09:17 PM
I winterize my Crusader using my outside shower connection. I connect it to the city water connection and pump antifreeze through everything but the water heater. When done I connect there shower hose to the black water flush and run antifreeze through that also.
10-28-2017, 09:20 PM
I blew the line out with air. No antifreeze in that line.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
10-28-2017, 09:45 PM
I never do anything to my black flush probably because I never thought of it. Maybe I am just lucky, I never had an issue and the winters here are brutal.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights / 2018 = 7 nights
10-28-2017, 10:03 PM
Always blow mine out with air.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
10-29-2017, 07:24 AM
I guess blowing out is another leg of protection, but I don't use air at all and I don't put anti in either, Why? If it's higher then the head and inlet there is no water in the line period. The valve itself doesn't hold water, never had a problem yet. But if I did blow my lines, I guess it wouldn't hurt being you have everything there already, would break a compressor out just to do that NO.
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2017, 07:34 AM
x2
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
10-29-2017, 08:54 AM
I didn’t realize that the valve didn’t hold any water. I may just be overly cautious.
10-29-2017, 09:23 AM
Think of it as a check valve
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2017, 09:27 AM
Hold on now,some systems use a rotating nozzle others use a spray head,the supply line coming to these is "Random" at best in loops and curves! Water can be trapped around the Nozzle attachment to Tank area! Your choice to gamble with your unit for a Little cost of A/F,vs cost to repair! Youroo!! PS next Spring your Buddy will say "Damn yours must be Plumbed Different than Mine"!
10-29-2017, 10:45 AM
Agree 100%. I prefer to gamble at the craps table!!
Ham Radio - W9EAA
10-29-2017, 10:49 AM
Getting paranoid in our old age? Don't burn all my firewood in that heated barn that you keep Molly in for the winter. [emoji120] [emoji15] [emoji482]
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2017, 10:56 AM
Who has a easy way of adding AF, to your black flush line, please don't tell me to take the shower hose apart, not all trailers have outdoor showers. It might help someone here, not to high jack the thread but the question has been asked what to do.
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2017, 11:16 AM
The black tank flush line is a line that goes from inlet on side of coach to an outlet inside black tank. It may have a loop or curve in the line that holds water. Simply Blow air through line to clear out any standing water. IMHO you do not need to try to get antifreeze in that line.
2011 Jeep JK Toad
10-29-2017, 11:25 AM
Hey W/D,you put Way to many Restrictions on this! We have been using "Your Firewood" in the courtyard during our "Family Five Drink Fest",Sorry you can,t be Here! Your "Ohio Family" said they will Drink 1 for You,I said they better drink a LOT more than that! Youroo!!
10-29-2017, 12:11 PM
NH Maple Maker
I use this.
http://www.forestriverforums.com/for...1&d=1509297100
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
10-29-2017, 12:19 PM
Originally Posted by russhd1997
I like that idea, not bad at all.
Coachmen M/H
Concord
2018 / 300 DSC
10-29-2017, 05:18 PM
The black tank flush is open on both ends which allow all water to drain out either into the black tank or onto the ground. The check valve/vacuum breaker doesn’t hold or trap any water.
10-29-2017, 06:24 PM
I saw a transfer pump like that at Menards for 7 bucks. Pretty sure it would be a good investment. My outside showers would not reach unless I devised a hose system to reach it. Think I’ll run some air through it then add a bit a AF to it. Just to be on the cautious side.
