Old 11-29-2015, 03:47 PM   #1
Winterizing but Water Pump not Pumping
Hi All-
This is my third winter as a travel trailer owner and I ran into an issue that I have not experienced before and I was hoping to get some help from the experts. I went through the typical winterizing process of by passing the hot water tank, pulling the drain plug on the hot water tank, etc. When I got to the step of putting antifreeze into the water lines, I noticed the water pump was not drawing in the antifreeze. I have a bypass line that sucks the antifreeze into the water system and I triple checked the bypass valve was positioned correctly. It is worth noting that my TT is connected to a city water hookup at a campground that has shut the water off for the winter. Therefore there is no water supply and the fresh water tank is empty. I was under the impression that as long as the antifreeze bypass line was hooked up, I wouldn't need water in the system but maybe that is my mistake. I think my next step is going to be taking a bunch of jugs of water to the campground to fill the fresh water tank to see if I can get the pump to start pumping again, but if anyone else has any thoughts it would be greatly appreciated.
~Brad
BHobbs20 is offline   Reply With Quote
Old 11-29-2015, 03:58 PM   #2
MNtraveler's Avatar
Check this thread for a similar problem and lots of responses.
Pump won't pull antifreeze {OP reports 'problem solved'}
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-29-2015, 04:27 PM   #3
ShowMeCamping's Avatar
I have found on my trailer that I have to place the jug of pink stuff on a step ladder to get it higher than the connection point entering the trailer. With the jug on the ground the pump will not draw it. I assume it has something to with the head height rating of these pumps, it's probably very minimal.
2015 Flagstaff Classic Super Lite 831FKBSS
2010 F250 Super Duty 5.4L
ShowMeCamping is offline   Reply With Quote
Old 11-29-2015, 04:34 PM   #4
Ford Idaho's Avatar
I have been using a 5 gallon bucket without issue.
Have you looked at the screen in the pumps bowl?
Old 11-29-2015, 06:12 PM   #5
my pump access is on the floor of my TT under the store. Generally when I am winterizing, the pink stuff is slightly above the pump. I have not had an issue with the pump drawing the liquid the past couple of years, so I am stumped this go around. I did not check the screen on the pump bowl, but I will add it to my checklist for the next go around.
Old 11-30-2015, 11:50 AM   #6
You can also hand pump the antifreeze thru the lines.
bigmac123 is offline   Reply With Quote
Old 11-30-2015, 04:37 PM   #7
Your pump not working
Hey there everyone. I had the same problem this year already. It turned out to be the outgoing check valve was completely stuck closed ! Partly from the city water pressure against it all summer. There is an outgoing pressure adjustment that you can remove and try to gently pull the valve out. Clean up the o ring etc and reinstall. It has plenty of lift if the pump is working properly.
klaatu is offline   Reply With Quote
Old 11-30-2015, 06:49 PM   #8
Pump not drawing pink stuff
Had same problem with 2015 Palomino. Had pump on for some time and nothing. Went to dealer and was told they also have problem but to keep pump on and raise the bottle. Did that and after a long time it started drawing and it only took a minute to have pink stuff flowing through faucet.
jrmorris is offline   Reply With Quote
Old 11-30-2015, 06:54 PM   #9
Flybob's Avatar
It is possible that there is still water pressure in the system. Try opening a faucet.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-30-2015, 07:53 PM   #10
Where is the outgoing check valve located? Is it on the pump? I will try and look for it.
There is no pressure in the system. When I turn the faucets on it is completely dry.
pump, water, water pump, winter, winterize
