Old 10-27-2014, 07:52 PM   #1
KDHfan's Avatar
Winterizing Checklist - Did I Miss Something?
Here's my winterization check list. First time winterizing myself... Can someone chime in to double check my process? Everything seemed to go easy enough, but I'd hate to open it up in the spring to broken pipes.
Name:	ImageUploadedByForest River Forums1414457571.626587.jpg
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 10-27-2014, 08:02 PM   #2
Jennifer9's Avatar
I don't know that I can add anything because I am new to this stuff but I may steal your checklist.
2015 Solaire 163X
2015 Chevrolet Silverado 1500 High Country
2009 Chevrolet Tahoe LTZ
Jennifer9 is offline   Reply With Quote
Old 10-27-2014, 08:23 PM   #3
asquared's Avatar
I always do a good clean of the entire trailer, especially the kitchen cabinets with Clorox wipes to kill any food odors. I will put bounce dryer sheets in cabinets to help deter pests/rodents and help keep it smelling good. I will also set out a bottle of peppermint oil with a piece of gauze sticking out of it. The odor of peppermint oil deters mice and is a pleasant odor to have in the trailer. Many will also stuff steel wool into every crevice to the outside they can find.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-27-2014, 08:27 PM   #4
mark0224's Avatar
Add remove Battery and put it on float charger
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 10-27-2014, 09:03 PM   #5
Canadiancrew's Avatar
Dump some antifreeze down the drains to fill the traps if you have not already done so when turning the taps on. Put some extra down to sit in the tanks in case they hold some water or sludge still.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 10-27-2014, 09:05 PM   #6
asquared's Avatar
Also if you have washer/dryer hook ups (used or not) run pink stuff through them too.
2014 Sabre 34REQS-6
Old 10-27-2014, 09:33 PM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
Keep those tires covered.
donanddona is offline   Reply With Quote
Old 10-27-2014, 09:59 PM   #8
Blow out black tank cleaner line.
mmunn is offline   Reply With Quote
Old 10-27-2014, 10:24 PM   #9
Just a member
kandl's Avatar
Good checklist. Add "remove water filter" for RVs with an on-board water filtration system. You wanna do this before the compressed air.
If the RV is gonna be sitting for months on end, a dehumidification product is a good idea. The Dri-z-air (calcium chloride) stuff works good.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 10-28-2014, 04:16 AM   #10
KDHfan's Avatar
Thanks guys!
I have no onboard filter... But my last one did. The place I had it winterized didn't remove it during the winter, which I found odd.
Also... My camper is in a pole building year round and is covered on all sides except the front... No sun, rain or snow on it, so I was thinking I didn't need to cover the tires. Any differing opinions?
2014 Toyota Tundra 5.7L CrewMax
winter, check list, winterize
