Old 09-24-2010, 03:18 AM   #1
EastlakeRoo's Avatar
Question Winterizing Compressed Air Inquiry
When winterizing, What is the typical amount of compressed air pressure used to blow out the lines? I don't want to little but then again I don't want to much. Thanks.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 09-24-2010, 04:34 AM   #2
rockin'ray's Avatar
I am not sure if this helps but I just recently bought a blow out plug to connect to the water inlet for this. On the package it says not to exceed 50 psi. Other than that I am not sure as this is our first year with a trailer so the winterizing isgoing to be a new experience.
rockin'ray is offline   Reply With Quote
Old 09-24-2010, 04:44 AM   #3
I've seen posts for 20 psi all the way up to 50 psi so I want to play it safe and see what others are safely using. I don't want to run into the situation of blowing lines.
2014 Wildwood 300BH
2011 Ford F350 FX4
Eastlake, OH
Old 09-24-2010, 06:17 AM   #4
i have always used 40 to 50 psi. it is lots of pressure. pull your drain plug on the hot tank first, then bypass the hot water, then start opening taps one at a time. don't for get the outside shower. i have had a few friends do that a few times. then just pour a couple of cups of anitfreeze down the drains.
skidoonut is offline   Reply With Quote
Old 09-24-2010, 06:32 AM   #5
Place press. reg. in air line before it goes into the adaptor plug at the city water inlet. This can be safely set at 40psi. Youroo!!
Old 09-24-2010, 06:40 AM   #6
3 Happy Campers's Avatar
40-50 psi is all the old gray plumbing systems could handle.
All current RVs use PEX, aka Cross-linked polyethylene
PEX can handle a lot more pressure than is really needed to clear the lines.
3 Happy Campers is offline   Reply With Quote
Old 09-24-2010, 07:31 AM   #7
I get the fitting into city water inlet, BUT WHat sorce of air are you all using?
2009 F150 SCREW4x4 Prodigy P3 and tow package Valley WDH and dual anti sway
2006 Party Barge 21 90 Merc Optimax
2011 RockWood 2702 SS arrived 11.10.2010
nights camped 2010 6
threegr8katz is offline   Reply With Quote
Old 09-24-2010, 07:39 AM   #8
I have a Dewalt 200 psi / 15 gal compressor in my garage.
You donít need anything that big .
A portable one big enough to run a nail gun will do the job just as well.
Old 09-24-2010, 07:43 AM   #9
kewl I think I have a friend with one of those.... any other ideas? How do you control the psi outage?
Old 09-24-2010, 07:47 AM   #10
All compressors have a regulator knob on them to dial in the pressure you need.
Every tool has its own psi requirements.
An inpact gun may use 90 psi & a brad nailer will use a lot less.
