Old 08-21-2011, 07:31 PM   #11
camping
tentcamper1's Avatar
Originally Posted by Willis View Post
Personally, after flushing the black and grey tanks for the season and closing them, I add a gallon of antifreeze to the black tank (the grey tank will get enough antifreeze in it just from filling the lines and traps). I don't think there is any way to know for sure that the tanks are completely dry and I don't want any residual water sitting against the valve areas to freeze. A gallon of antifreeze is cheap insurance.
x2-
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 08-21-2011, 07:46 PM   #12
X3
That's the same procedure that I've been following w/ no issues up here in Ontario.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-21-2011, 09:31 PM   #13
After pulling the anode rod and drain the water heater I use a wet and dry vac to pull out the remaining water...you would be surprised how much gets left behind.
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 11-07-2011, 11:06 AM   #14
trudinator's Avatar
I flushed out our gray and black water tanks yesterday before winterizing. We're using the blow-out method. I couldn't believe how much "gunk" (I won't go into nasty details) was still left in the tanks. I rinsed and dumped them three times to make sure they were both clean as a whistle. Should I leave the dump valves open during winter? DH drained the water heater and apparently didn't read the info about the residual pressure....he came away totally soaked!
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 11-07-2011, 08:57 PM   #15
Anacortesians
The temperature at which water with "stuff" in it will freeze declines as a function of the percentage of "stuff". Your black tank contents probably wouldn't freeze until about 24 degrees, but why would you leave that stuff in there? Grey tank would probalby be OK down to about 28 degrees, but again, why would you leave stuff in there?
If both tanks are at relatively low content levels (say less than a quarter full) there's enough air space for them to freeze without doing any damage.
Frank and Eileen
No longer RVers or FR owners
black tank
