Old 09-21-2013, 07:18 AM   #11
camper1999's Avatar
I first purge the lines with air then use around 3 gallons. I also make sure I get anti freeze into the black flush and water tank lines and all the sink/shower traps. I also make sure anti freeze gets into the kitchen sink sprayer if you have one. I also use damp rid. If your unsure use extra anti freeze it is cheap compared to the pain/expense of a plumping repair.
2011 GMC 2500HD Diesel
Old 09-21-2013, 07:21 AM   #12
Rrickim63's Avatar
X10
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 09-21-2013, 09:31 AM   #13
Originally Posted by 2Macs View Post
I quit using anti-freeze in my water lines years ago. I put an air pressure plug from Camco in my city water connection and attach a air line from my compressor set to 40 lbs. Then, I go through and open faucets until all I get is air. After making sure all water is out of the lines, I open my low water point drains until only air comes through. Finally, I dump the holding tanks. The only place I use anti-freeze is the drain traps. A gallon of anti-freeze lasts me about three years. I have never had a problem with leaks prepping in the spring and it makes sanitizing the water system much easier.
X3
latner is offline   Reply With Quote
Old 09-21-2013, 09:46 AM   #14
When you guys refer to low drains. Do u mean the hot and cold water lines outside that kind of hang down near the tires back by the water pump?
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 09-21-2013, 09:48 AM   #15
I buy 2 gal., I can get the plumbing done with 1 Gal. but do not feel the traps have enough, so with the other gallon; 2 sinks and tub gets a bit and the rest down the head in hopes to get some antifreeze around the drain valve to keep the little water that is there from freezing.
As others have said don't forget to switch the bypass valves on the hot water tank. If you don't close the valve its a waste of antifreeze.
I blow all the lines out with air to the best of my ability thru the city water connection, this gets the water out of the city water line and check valve, but this leaves some water in my pump and lines between the pump and city water. So I still run antifreeze thru the lines after. This also gets any water droplets out of the valves in the faucets and toilet valves. A small bit of water in one of those valves can mess them up.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 09-21-2013, 12:50 PM   #16
Pug Dads
cheatham09's Avatar
I think it all depends where you live and how you use the camper, live in North Carolina here. Leave heat on at 40. But we camp on weekends in the winter months.
cheatham09 is offline   Reply With Quote
Old 09-21-2013, 02:27 PM   #17
PHS79's Avatar
Last winter I decided to use air to blow out the lines with air, I had the problem that even after letting air blow through the cold water side of the kitchen faucet for more than 10mins (50psi and opening closing the faucet numerous times) I still could hear "gurgling" in the line. Since I could hear the gurgling I knew there must be water in the in the line yet, and since we live in Wisconsin and can get temps as cold as -30 and wind chills down to -50, I ended up using the good old pink antifreeze to make sure that I had it done right. I use 2 gallons to do our Grey Wolf, its about 1.25 to do the lines and the rest goes down the drains and the toilet.
When I put the camper in the shed of the winter I park it on 2x10s to keep the tires off the concrete, I also place dryer sheets all over inside the camper and also stuff them around all the tanks.
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 09-21-2013, 02:59 PM   #18
Ford Idaho's Avatar
Blowing water uphill?
Gonna do this as well.
How to Use Moth Balls as Spider Repellents | eHow
Put one inside the outside cover for my hot water tank.
Old 09-21-2013, 03:05 PM   #19
DAISY BOYKIN's Avatar
I use------------
I use one fifth of JD! That will just about get the job done!
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
antifreeze, winter, winterize
