Old 09-20-2013, 10:20 AM   #1
Winterizing How much antifreeze
Hi,
How much RV antifreeze will I need to winterize my camper? Anything else do people usually need to purchase to winterize there camper? Getting ready to make an order and trying to get everything I need for winter.
2013 Rockwood Mini 2503S
2011 Chevrolet Silverado 1500 5.3L
Bryan2503S is offline   Reply With Quote
Old 09-20-2013, 10:26 AM   #2
Triguy's Avatar
I buy two gallons of the pink stuff.
I also buy damprid to place in the trailer to help mitigate the effects of moisture.
There's a bunch of good reading here on winterizing.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-20-2013, 10:31 AM   #3
Ford Idaho's Avatar
I have the built in winterizing kit.
I was told 2-3 gallons is what I should need.
Be sure to close the water heater bypass valve.
I plan on putting in some dehumidifying crystals in the bedroom and on the kitchen counter.
Then under the trailer I will stuff the holes with steel wool to keep out any fur bearing squatters.
I will also get the tires off the ground.
Old 09-20-2013, 11:09 AM   #4
You need about 2 gals of antifreeze. Not sure if the 2503S comes with connection to antifreeze. In my case made hose to connect between pump inlet and the antifreeze jug. You don't want to fill the water filter canister with antifreeze so bypass it or use sealed pop bottle inside of canister. If you decide to purge lines with air you require adapter from water inlet to air line (not expensive). btw, I love the layout of the 2503S but need larger TV to pull one . sigh
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 09-20-2013, 11:10 AM   #5
The FAQ page, duh, I kept searching in Gen Tech wondering where all the stickys where. Thanks!
Old 09-20-2013, 11:44 AM   #6
rotorhead1250's Avatar
Mine only uses 1 gal. When all the faucets are purged and anti-freeze runs out, I’m done. I then pull the plugs on the low level drains and remove the anode from the heater. I also ensure fresh tank is empty by pulling that plug too.
Matt & Kathie
2017 Grey Wolf 27RR
rotorhead1250 is offline   Reply With Quote
Old 09-21-2013, 03:45 AM   #7
cpaulsen's Avatar
I use approx. 1 gallon....just enough to put in the sink traps and toilet.
cpaulsen is offline   Reply With Quote
Old 09-21-2013, 05:11 AM   #8
Oakman's Avatar
I'll have to try Damprid this year, that's a great idea for winterizing.
I use about three gallons of the pink stuff in the Silverback.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 09-21-2013, 06:19 AM   #9
I quit using anti-freeze in my water lines years ago. I put an air pressure plug from Camco in my city water connection and attach a air line from my compressor set to 40 lbs. Then, I go through and open faucets until all I get is air. After making sure all water is out of the lines, I open my low water point drains until only air comes through. Finally, I dump the holding tanks. The only place I use anti-freeze is the drain traps. A gallon of anti-freeze lasts me about three years. I have never had a problem with leaks prepping in the spring and it makes sanitizing the water system much easier.
2Macs is offline   Reply With Quote
Old 09-21-2013, 06:47 AM   #10
Crusader's Avatar
2X ....... I do the same as above. I think its safer this way. No liquid in the lines at all.
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
antifreeze, winter, winterize
