Old 10-28-2011, 12:29 AM   #11
ken0042's Avatar
^^ Very easy to winterize; but sounds like a pain come spring time. You would need a fair amount of water to flush the antifreeze out the tank.
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 10-28-2011, 10:36 AM   #12
Titleguy's Avatar
Originally Posted by Jsr9878 View Post
All you need to do is pour your antifreeze in your fresh water tank, close the HWH valves turn on your pump and run through you system. Very easy !!
I think the point of the winterizing kit is to avoid pouring the antifreeze into your fresh water tank. 1) you use less antifreeze and 2) you don't have to try and flush it all out of the fresh water tank next spring.
Titleguy is offline   Reply With Quote
Old 10-28-2011, 01:23 PM   #13
Jsr9878's Avatar
Nope very easy to flush out. I only use 3-4 gallons of antifreeze. It's easier than tapping into the plumbing system and having more clamps to worry about coming loose, and the time and cost to do it. Besides you really should sanitize and flush your fresh water tank anyway.
Jsr9878 is offline   Reply With Quote
Old 10-28-2011, 01:41 PM   #14
Titleguy's Avatar
I guess we can agree to disagree on a couple of points. My RV pump converter winterizing kit cost me $12.52 from Amazon and it only took 1 1/2 gallons of antifreeze to winterize the whole trailer. I have one more fitting, but no more clamps than the original set up so additional clamps are not an issue.
I do agree that you need to sanitize and flush your fresh tank though (although I don't think anti freeze is the product to do it with).
Old 10-29-2011, 06:04 AM   #15
Jsr9878's Avatar
You stick a hose in the tank with the drain open a few times, then you put a little bleach in the tank set for a couple of hours then flush again. To each his own I guess!
Old 10-29-2011, 06:36 AM   #16
KyDan's Avatar
What HE said!!
Antifreeze leaves a slight taste and makes the water foam at first in the
spring. It goes away in a couple days use of the water system.
I definitely don't want the extra taste and foam from putting antifreeze in
my fresh water tank. And I'm a tight wad. I also can do the job with
less than 2 gallons by not putting any in the fresh tank.
I open my fresh tank drain valve when I'm coming home the last trip of the
season and it sloshes pretty near totally empty that way.
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 10-29-2011, 11:32 PM   #17
ken0042's Avatar
As others have said- that is a LOT more antifreeze than I use. This was my first winterization so I ran the taps a little longer than I think I needed to; and only used 1-1.5 gallons.
As for the "easy to flush out" part; I would think to get all of it out you would need 10-15 gallons of water to flush the system out. That is quite a bit of water going into the grey tank; and that needs to be dumped before the first camping trip in the spring. Last year my de-winterization only put a couple of gallons; which I was able to dump into a Home Depot bucket.
I suppose if you have easy access to dump your tank after de-winterizing your idea is OK. I do also like having the syphon available in the plumbing. Last year I had to try and "MacGyver" a way to put water into the fresh tank when boondocking. Now having the syphon there it would be easy to draw water right from a portable water container.
Wolf Pup T16P owner
Old 10-29-2011, 11:38 PM   #18
TURBS's Avatar
I used 5 gallons ....... and this is what you may not understand , campers of different lengths have longer or shorter plumbing .
Also my camper for example has and outside kitchen "extra sink and plumbing" I also have an outside shower as well as the normal toilet inside sink and inside shower .
Old 10-30-2011, 01:07 AM   #19
ken0042's Avatar
Yes, I am aware that different trailers will use different amounts; especially if you have extra fixtures. I just can't see his method using less than the syphon method; and most likely more.
Wolf Pup T16P owner
Old 10-30-2011, 08:11 AM   #20
tom50mg's Avatar
Winterizing !
fIRST I DRAIN ALL OF THE FRESH WATER,EMPTY THE FRESH WATER HOLDING TANK,I REMOVE THE WATER FILTER AND REMOVE THE WATER AND REINSTALL,THE PREVIOUS OWNER TOOK THE ELEMENT OUT,NO SEDIMENT IN THERE IN MY CASE,TAKE THE DRAIN OUT OF THE WATER HEATER [AT THIS TIME YOU CAN CHECK AND REPLACE THE SACRIFICIAL ANNODE] RUN THE WATER PUMP FOR A FEW SECONDS WITH ALL OF THE TAPS OPEN,AND THE SHOWER OPEN AS WELL,BLOW OUT ALL DRAINS OR P TRAPS,I MADE A FITTING THAT FITS IN THE WATER HEATER DRAIN WITH A QUICK CONNECT FOR MY COMPRSSOR HOSE,BLOW OUT LINES WITH LOW PRESSURE,30 SECONS OR SO SHOUL DO IT, REMOVE AIR BLOW OUT PUG FROM WATER HEATER NOW,CLOSE ALL THE TAPS NOW,RE-INSTALL THE ANNODE,CLOSE WATER TANK DRAIN,CLOSE THE BY-PAS VALVE ON THE WATER TAK,INSIDE OF TRAILER USUALLY,I MADE A FILL PUMP WITH A SPARE WATER PUMP I TAKE WITH ME ON TRIPS IN CASE I SHOULD NEED A PUMP,ANYWAY HOOK THE HOSE YOU MADE TO CONNECT TO THE FRESH WATER SUPPLY AND SYCK THE R/V ANTIFREEZE RIGHT INTO THE TRAILER PLUMBING,OPEN 1 TAP AT A TIME TO ENSURE YOU HAVE ANTIFREEZE AT THAT POINT...THATS IT,YOU WILL BE SAFE...TOM OH YA DON,T FORGET TO EMPTY THE GRAY WATER AND BLACK WATER HOLDING TANK,S...USE SOME HOLDING TANK ADDITIVE TO KEEP THE DRAIN VALVES LUBRICATED.
tom50mg is offline   Reply With Quote
