Old 10-26-2011, 06:09 PM   #1
Send a message via Skype™ to toshu
Winterizing kit-- DIY or Camco??
I need to winterize my TT, and have read a lot of helpful posts here.
Since my TT is a 2011, it has the HW bypass and the water filter. What it does not have is an adapter for adding Anti freeze. I see that Camco makes an inexpensive kit but have read folks complained about the hose length(too short) and the small ports on the 3 way valve.....
Soooo.... I was wondering, does anyone have a parts list for a DIY kit, or is the Camco kit OK and worth buying????
-2009 Ford F-150, SuperCab w 8 ft bed
5.4L Screw, 3.73 rear, 8200 GVWR
-2011 Rockwood 2604, 2x6V Interstate U2200 batteries,Yamaha 2400 genny
-2011-23 nights
toshu is offline   Reply With Quote
Old 10-26-2011, 06:13 PM   #2
TURBS's Avatar
I did my own with pex push lock fittings and took no time at all .
It cost more but I do nothing the cheap route !
but the camco kit will serve you just fine to .
Do what you feel you can handle and afford
Old 10-26-2011, 06:18 PM   #3
On Amazon, the kit is only about 13 bucks, however, I plan on camping during the winter months, therefore I will be doing the winterizing cycle more than once a year and want it to be relatively easy and fool proof.
-2011-23 nights
Old 10-26-2011, 06:32 PM   #4
TURBS's Avatar
easy and fool proof ................ buy the kit
even easier would be to un hook fresh water supply line to the pump put a simple 1/2 pipe to hose barb fitting in its place then attach a 1/2 hose to it then suck antifreeze from the bottle . reverse procedure when done
Old 10-26-2011, 06:49 PM   #5
That sounds good BUT....my plumbing is in the storage area of the TT and I crawled in there yesterday...Ugh...
I figure something permanent/once and done, like a 3 way valve set up that can stay there would be the best in my situation. The Camco kit does that, but I have heard folks complain that the ports/flow are too small on the valve....dang...nothings simple.
-2011-23 nights
Old 10-26-2011, 06:52 PM   #6
TURBS's Avatar
lol . sorry !
short of me doing it for you thats what I have to offer !
I think if you take your time and do it right and think out all the possibilities you will be happy in the long run .
I am sure you'll get more answers and maybe better solutions to your question .
hold on tight the Calvary will come !
by the way other than the time rounding up parts my install diy took an hour .
I can reach inside my cubby hole and turn valve then hook up my hose to my antifreeze and suck away in 15 seconds or less
Old 10-27-2011, 11:18 AM   #7
Titleguy's Avatar
I just installed the camco kit from amazon. I can't say for sure because I have only run the antifreeze since installing it, but it flowed out of the taps as fast as water normally does, so I did not notice a decrease in flow.
Titleguy is offline   Reply With Quote
Old 10-27-2011, 11:22 AM   #8
Ok, thanks for that note, maybe Camco addressed the problem. I will go ahead and order it.
-2011-23 nights
Old 10-27-2011, 11:52 AM   #9
Big Dawg's Avatar
Just bought the Camco last night. I had to buy a couple of fittings to make it work, and have to install it. I will let you all know how it works.
2004 Chevy Avalanche Z66 W/Transmission Cooler
2011 Grey Wolf 28BH
Blue Ox Sway Pro WDH
2 Beagles (Snoopy & Dexter)
Big Dawg is offline   Reply With Quote
Old 10-27-2011, 08:39 PM   #10
Jsr9878's Avatar
All you need to do is pour your antifreeze in your fresh water tank, close the HWH valves turn on your pump and run through you system. Very easy !!
Jsr9878 is offline   Reply With Quote
