View Poll Results: How do you winterize?
blow out lines with air, pump AF throughout 64 39.26%
only blow out lines with air, pour some AF down toliet(s) and sink(s) 36 22.09%
only blow out lines with air, don't use AF at all 5 3.07%
only use AF, don't blow out lines 54 33.13%
other 4 2.45%
Voters: 163. You may not vote on this poll
Old 10-22-2015, 10:44 PM   #11
acadianbob's Avatar
Originally Posted by Ontherock View Post
I've been using compressed air to blow out the lines and just add the pink stuff to the traps. Been doing that for the last few years with no problems.
FWIW, my RV dealer warned me against that saying that it takes very little water in the water pump to break it.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
acadianbob is online now   Reply With Quote
Old 10-23-2015, 09:15 AM   #12
ptt87's Avatar
Thanks for initiating this poll - very informative. I wouldn't mind seeing the same poll taken with a geographical spin.
I'm curious to know what folks do here in Georgia. I personally blow out my lines and then pump AF throughout just to be safe, but have often wondered if that's overkill for my location.
Pete & Laurel
Peachtree City, GA
2012 Surveyor SP280
2007 Ford F-150, 4.6L V-8
Equal-i-zer
ptt87 is offline   Reply With Quote
Old 10-23-2015, 09:32 AM   #13
cogito ergo moo
Cowracer's Avatar
Water is only an issue when there is no room for it to expand as ice. You could have a sealed tank 3/4 full and not have an issue when it freezes. Blowing the lines might leave drops of water here and there, but there is enough 'air-space' that it's not a problem. Once I get my compressor hooked up, I will run the water pump for a few seconds to blow out the water.
The reason I blow instead of using A/F is that my first camper was an 89 Winnebago Class A. The prior owner "winterized" it by dumping about 5 gallons of A/F in the freshwater tank, and then running all the faucets till it came out pink. Nothing ever froze, but despite NUMEROUS flushes, sanitizing and every other thing I could try, the fresh water system still had a distinctive and unpleasant A/F taste to it. To the point of having to haul bottled water around for coffee, drinking and doing dishes.
I vowed that I would never EVER use A/F in my freshwater system anywhere again. I honestly would rather replace broken lines or the pump than deal with the A/F taste again.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 10-23-2015, 09:49 AM   #14
acadianbob's Avatar
Tim
Two things there. Not sure if the air pressure actually goes through your pump. And there's not much room in that pump. Also, you never put AF in the fresh tank. You use a valve and hose on your pump inlet to switch between the fresh water tank and a tube where you can suck AF out of the bottles. AF in the fresh water tank is a mistake.
Old 10-23-2015, 09:54 AM   #15
Islander's Avatar
Pacific Northwest
Parked in my yard
All tanks drained
Blow out lines and HW tank
Add A/F via water pump to lines (only)
A/F down the drains to fill the traps
Remove any liquids...even dish soap
Leave nothing that would invite rodents
Remove batteries
Slides in
Heaters set to come on just above freezing
(set at - just to take the chill off and move the air)
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 10-23-2015, 10:02 AM   #16
CWSWine's Avatar
Originally Posted by mud yapster View Post
I just blow out the lines and drain HW tank. No pee traps in ours so no AF down drains. No issues so far in 20 plus years but we have mild winters here and us the RV year round.
Voted
You don't have those U shaped pipes under you sinks? Those are to prevent the smell from you gray tanks coming back the drains for the tanks. I have never seen sinks without one but I guess it's possible.
i do both air and AF but I but probably over doing it but only takes me a few minutes to do it.
Voted
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 10-23-2015, 10:32 AM   #17
The results are a little surprising so far. I expected the blow out with air & use AF choice to be first, and it is, but I didn't expect the AF only choice to be second.
I figured the two "air only" choices would be higher.
Iwritecode is offline   Reply With Quote
Old 10-23-2015, 11:09 AM   #18
Future Roo 23IKSS Owner
elundquist's Avatar
If you use AF and have not seen my posts under "vinegar vs. ammonia" you should review.
http://www.forestriverforums.com/for...d.php?p=989794
I was surprised to learn some RV antifreeze contains methanol or ethanol! These are not compatible with the polyethylene tank (Black, Gray, & Fresh water). It makes holes in the tank!
I used an AF with ethanol once and it did leave a taste in the water stored in the FW tank. It soaks into the plastic and leached out into the stored water. The wife has required bottle water since for consumption, even though it's been three years and I can't taste it anymore.
I now make sure the RV AF doesn't contain methanol or ethanol. Most of time the labels state if it has alcohol, but all ways check the MSDS as I found one brand listed special blended inhibitor and reading the MSDS indicated the inhibitor was ethanol!
If the label states it is flammable that your sign to leave it on the shelf!
Erik Lundquist
iPhone 6S using Tapatalk
elundquist is offline   Reply With Quote
Old 10-23-2015, 11:19 AM   #19
I bought this stuff from Menard's. It seems to be ok.
MSDS here.
Old 10-23-2015, 11:29 AM   #20
elundquist's Avatar
I think it was a Splash Pool/RV AF I got from Lowes the one year that contained ethanol. The pool AF always seam to have ethanol. You need to check each time as they reformulate all the time. I am finding more that advertise they are alcohol free.
It interesting they advertise this is good to -50 deg, but the MSDS indicates the freeze point at 9 deg?
Erik Lundquist
winter, winterize
