View Poll Results: How do you winterize?
blow out lines with air, pump AF throughout
64 |
38.32% |
only blow out lines with air, pour some AF down toliet(s) and sink(s)
36 |
21.56% |
only blow out lines with air, don't use AF at all
5 |
2.99% |
only use AF, don't blow out lines
57 |
34.13% |
other
5 |
2.99% |
11-08-2015, 07:39 PM
#41
voted
Blow and pump the pink stuff
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
11-17-2015, 09:29 AM
#42
Broken Toe
I'm dying here
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
11-21-2015, 10:58 AM
#43
Happy Camper
Has anyone ever had a problem blowing out the air and then pouring AF in the traps? It has always worked for me, but I live in Alabama. Sometimes it does get down around 0 F here in winter. It might depend on where you live, but if the antifreeze is not needed in the lines, why do it?
11-21-2015, 11:15 AM
#44
Originally Posted by Cowracer
I see you have a keen sense of the obvious.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
11-22-2015, 01:25 AM
#45
There are 50 pages or so of opinions about this in the winterizing section under general Forest River community. It depends on who you ask. Some of us believe blowing out the lines doesn't get every last bit of water out and the remnants can remain in faucets and connectors as well as pool in low points. Stand by for opposing opinions.
Here's a little experiment I'm thinking of videotaping. Take a gallon milk jug and rinse it out. Turn it upside down and let all the water out. Shake it vigorously and repeatedly until all the water is out. Set it down on the counter and come back in 10 minutes. Turn it upside down and pour the rest of the water out.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
11-22-2015, 06:09 AM
#46
Beating a dead horse but It depends a lot on where you live and the RV. But to answer your question. Yes If you do it alone & miss getting all the water out of a valve or an end point. Such as a toilet valve or a spray connection. With the pink stuff you can see that it is there.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
11-22-2015, 08:02 AM
#47
Happy Camper
Sure, there are lots of opinions. I didn't ask for opinions.
11-22-2015, 08:23 AM
#48
What do you mean by "blowing out the air"?
Sent (I think)
11-22-2015, 08:30 AM
#49
Happy Camper
Sent (I think)
Should be blow out WITH air...
11-22-2015, 08:31 AM
#50
I think we all know what he means. He simply used the wrong word. He typed "the" instead of "with."
Bruce
11-22-2015, 09:22 AM
#51
only blow out lines with air, pour some AF down toilet(s) and sink(s). I do this several times between late November and early March. We use the RV year round tho only 4 or five times between Nov and March.
Joe & Beverly
2014 Ram 2500 CTD, CC, SB
2014 8289WS lifted
11-22-2015, 09:34 AM
#52
I blow the lines out with air and fill with AF (bypassing the water heater and fresh water tank.)
Jerry & Sheryl
2015 Rockwood 8280WS
2012 Ram 1500 Laramie 5.7 Hemi 3.92 RR
11-22-2015, 06:13 PM
#53
You did "if the antifreeze is not needed in the lines, why do it?"
11-22-2015, 07:03 PM
#54
Happy Camper
Well, obviously that question was a bit rhetorical. There is no reason to do it if it is not needed, unless one wants to waste time, money, and resources.
People are certainly welcome to express opinions in this thread, but I was trying to determine if anyone has actually had problems.
11-23-2015, 09:17 AM
#55
You only realize you "needed" antifreeze AFTER you discover the cracked, spewing, water spraying all into your rv when you hook up the system as you leave on a trip!!
I used the "air" and trap method for years; not anymore!! 😳 I hate bad surprises!
We live in Atlanta.
Remember all of those little elbows in your piping are "plastic" and any droplets of trapped water can force a crack.
With these new ez winterization systems why risk it? Takes 10 more minutes and 3 gallons of RV Antifreeze.
I drain; use air; pump anti freeze.
30 minutes start to finish.
We re winterize a few times a season.
11-23-2015, 10:18 AM
#56
Happy Camper
We live in Atlanta.
Just to be clear, are you saying that you had pipes to burst after using the air and trap method in Atlanta?
11-23-2015, 01:34 PM
#57
AF only. When I see pink, I know I'm done. I start with the outside shower since it is the furthest, then the toilet, then the bathroom sink, and lastly the kitchen. Uses two gallons. The third gallon fills the the traps and several inches in the toilet to keep the seal moist throughout the winter.
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
11-23-2015, 04:13 PM
#58
Cracked fitting in Atlanta
YES! Fortunately I stopped at a local RV center and fixed it in 20 minutes!
Was heading to Florida in December.
Fitting was a plastic "L" in back of toilet. Was a 2011 Keystone fifth wheel. Traded because of floor plan. Was good unit.
11-23-2015, 05:15 PM
#59
I would bet that the line running to the toilet would be the most susceptible to having water left in it if you only blow out the lines with air. I wonder how many people think to depress the foot pedal while the air is being blown through. I'm not sure I would.
11-23-2015, 09:48 PM
#60
Seasonal
