View Poll Results: How do you winterize?
blow out lines with air, pump AF throughout 64 39.26%
only blow out lines with air, pour some AF down toliet(s) and sink(s) 36 22.09%
only blow out lines with air, don't use AF at all 5 3.07%
only use AF, don't blow out lines 54 33.13%
other 4 2.45%
Voters: 163. You may not vote on this poll
Old 11-02-2015, 11:37 PM   #31
MNtraveler's Avatar
Winterizing Poll
IMHO, there is too much focus on clearing "water in the lines" and not enough on clearing out and and then anti-freezing the bits of water still trapped here and there in joints, angles and faucets. Case in point, our h/w heater line has a 90-degree metal fitting the elbow of which points to the ground - a perfect place for residual drops of water to roll back to, collect and freeze. Or any faucet valve.
Some people also aren't noting where they live. Here in MN we are blowing out, adding antifreeze and leaving it in the system. We are looking at 20-30 below for 1-3 weeks most years and occasionally worse. Easily enough for a few drops to snap a fitting. That is much different from what may be needed in warmer climates.
Good article attached. (Sorry, pages are in reverse order.)
Name:	ImageUploadedByForest River Forums1446528888.720925.jpg
ID:	93599Click image for larger version
Name:	ImageUploadedByForest River Forums1446528903.762123.jpg
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-03-2015, 03:51 AM   #32
mud yapster's Avatar
Although we don't drink the water from our new RV I still won't us RV AF and contaminate my water lines with it. We blow all the lines free of water and drain the HW tank. Easier to do and a lot cleaner and safer. I have a fitting that hooks to the air compressor and fresh water line inlet. Then go inside and open each valve one at a time.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-03-2015, 04:57 AM   #33
Oaklevel's Avatar
It is election day go vote
or you can camp like our neighbor did last weekend in the next site........ have a camper use whats in it ....don't hook up any water or electric & camp in a tent beside it.......... safest way ??????
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 11-05-2015, 06:16 PM   #34
MNtraveler's Avatar
So you believe you are getting all the water out with compressed air?
In what way does RV antifreeze "contaminate" the lines? 45% of propylene glycol manufactured each year is used in food production.
2016 Forester 2401R
Old 11-08-2015, 02:08 PM   #35
Summer2Go
Summer2Go's Avatar
What does the compressor fitting look like?
Summer2Go is offline   Reply With Quote
Old 11-08-2015, 03:24 PM   #36
MNtraveler's Avatar
This.
Name:   ImageUploadedByForest River Forums1447017851.176918.jpg
2016 Forester 2401R
Old 11-08-2015, 03:29 PM   #37
MNtraveler's Avatar
Sorry for the double post and actually that is not correct. It has to be the male hose fitting. Like this.
Name:   ImageUploadedByForest River Forums1447018173.192467.jpg
2016 Forester 2401R
Old 11-08-2015, 05:31 PM   #38
Engineer of Crazy Train
ChooChooMan74's Avatar
I made my own. I change the quick connect to a barbed nipple for sucking antifreeze.
Sent from my Samsung Note 4 using Tapatalk.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 11-08-2015, 05:35 PM   #39
MNtraveler's Avatar
Attachment 93908
What powers the fluid? It looks like you might have a special "antifreeze in" port? So there's no compressed air involved here...?
Old 11-08-2015, 06:16 PM   #40
I blow and pink stuff. Yes i do have an AF port.
Locomotive Engineer
winter, winterize
