View Poll Results: How do you winterize?
blow out lines with air, pump AF throughout 64 39.26%
only blow out lines with air, pour some AF down toliet(s) and sink(s) 36 22.09%
only blow out lines with air, don't use AF at all 5 3.07%
only use AF, don't blow out lines 54 33.13%
other 4 2.45%
Voters: 163. You may not vote on this poll
Old 11-22-2015, 08:22 AM   #51
PhoneDude 8289's Avatar
only blow out lines with air, pour some AF down toilet(s) and sink(s). I do this several times between late November and early March. We use the RV year round tho only 4 or five times between Nov and March.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 11-22-2015, 08:34 AM   #52
xs1ve's Avatar
I blow the lines out with air and fill with AF (bypassing the water heater and fresh water tank.)
Jerry & Sheryl
2015 Rockwood 8280WS
2012 Ram 1500 Laramie 5.7 Hemi 3.92 RR
xs1ve is offline   Reply With Quote
Old 11-22-2015, 05:13 PM   #53
MNtraveler's Avatar
Originally Posted by Tonylmiller View Post
Sure, there are lots of opinions. I didn't ask for opinions.
You did "if the antifreeze is not needed in the lines, why do it?"
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 11-22-2015, 06:03 PM   #54
Happy Camper
Tonylmiller's Avatar
Well, obviously that question was a bit rhetorical. There is no reason to do it if it is not needed, unless one wants to waste time, money, and resources.
People are certainly welcome to express opinions in this thread, but I was trying to determine if anyone has actually had problems.
Tonylmiller is offline   Reply With Quote
Old 11-23-2015, 08:17 AM   #55
SilverbackMel's Avatar
You only realize you "needed" antifreeze AFTER you discover the cracked, spewing, water spraying all into your rv when you hook up the system as you leave on a trip!!
I used the "air" and trap method for years; not anymore!! 😳 I hate bad surprises!
We live in Atlanta.
Remember all of those little elbows in your piping are "plastic" and any droplets of trapped water can force a crack.
With these new ez winterization systems why risk it? Takes 10 more minutes and 3 gallons of RV Antifreeze.
I drain; use air; pump anti freeze.
30 minutes start to finish.
We re winterize a few times a season.
SilverbackMel is offline   Reply With Quote
Old 11-23-2015, 09:18 AM   #56
Happy Camper
We live in Atlanta.
Just to be clear, are you saying that you had pipes to burst after using the air and trap method in Atlanta?
Old 11-23-2015, 12:34 PM   #57
mlangdn's Avatar
AF only. When I see pink, I know I'm done. I start with the outside shower since it is the furthest, then the toilet, then the bathroom sink, and lastly the kitchen. Uses two gallons. The third gallon fills the the traps and several inches in the toilet to keep the seal moist throughout the winter.
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is offline   Reply With Quote
Old 11-23-2015, 03:13 PM   #58
Cracked fitting in Atlanta
YES! Fortunately I stopped at a local RV center and fixed it in 20 minutes!
Was heading to Florida in December.
Fitting was a plastic "L" in back of toilet. Was a 2011 Keystone fifth wheel. Traded because of floor plan. Was good unit.
Old 11-23-2015, 04:15 PM   #59
I would bet that the line running to the toilet would be the most susceptible to having water left in it if you only blow out the lines with air. I wonder how many people think to depress the foot pedal while the air is being blown through. I'm not sure I would.
Iwritecode is online now   Reply With Quote
Old 11-23-2015, 08:48 PM   #60
Platokidd's Avatar
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
winter, winterize
