View Poll Results: How do you winterize?
blow out lines with air, pump AF throughout
64 |
38.32% |
only blow out lines with air, pour some AF down toliet(s) and sink(s)
36 |
21.56% |
only blow out lines with air, don't use AF at all
5 |
2.99% |
only use AF, don't blow out lines
57 |
34.13% |
other
5 |
2.99% |
10-22-2015, 02:47 PM
Winterizing Poll
Just curious who does what.
10-22-2015, 02:54 PM
Voted!
10-22-2015, 02:59 PM
We camp all winter long here in Central Oregon. I drain and then use antifreeze after every trip once we start seeing temps drop into the teens at night and not above freezing during the day.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
10-22-2015, 03:05 PM
I've been using compressed air to blow out the lines and just add the pink stuff to the traps. Been doing that for the last few years with no problems.
10-22-2015, 03:11 PM
I use AF only.
#1 reason is that I can winterize at the storage yard (don't have to bring camper home) only having to bring my battery. Bring the battery and LP tanks home, and I'm done. But of course, de-winterizing with AF is a process, versus nothing really to do if you only blow out with air.
To a lesser degree, I like knowing that I have removed every bit of water from the lines. It's possible for air to shoot across the top of water at a low point in the hose, leaving. There are techniques for minimizing this risk (hitting with air multiple times, etc), and I know that a small amount may not be enough to rupture a hose.
The time to run AF or to blow with air is about the same.
IMO, if you are going to run AF, blowing out with air first is a complete waste of time and energy.
10-22-2015, 03:15 PM
Both!
I have to do both....it got down to -20 below here in Colorado last winter and I've seen a little water inside my brass sprinkler system crack it so don't want cracked lines, water heater, or water pump in the camper.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
10-22-2015, 03:28 PM
Future Roo 23IKSS Owner
Winterizing Poll
I live in the mountains of Colorado, so below freezing temps are common. I blow out the system to remove slugs of water. I then pump AF into the system. The protection is the antifreeze and blowing the system quickly with air is to remove most of the water.
I only have a small twin tank job site compressor, so it can not provide enough air to clear the system of all water.
Why bother with air? To remove water from the city water connection & force water out to prevent it from diluting the antifreeze.
Erik Lundquist
iPhone 6S using Tapatalk
10-22-2015, 09:49 PM
Broken Toe
voted. I blow (easy turbs) and use A/F in the drain trap, although i forgot one year with zero issues.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016 Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
10-22-2015, 09:57 PM
Engineer of Crazy Train
Belt and suspenders!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 - 18
Come read my Camping Blogs
10-22-2015, 09:59 PM
I just blow out the lines and drain HW tank. No pee traps in ours so no AF down drains. No issues so far in 20 plus years but we have mild winters here and us the RV year round.
Voted
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
10-22-2015, 10:44 PM
FWIW, my RV dealer warned me against that saying that it takes very little water in the water pump to break it.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
10-23-2015, 09:15 AM
Thanks for initiating this poll - very informative. I wouldn't mind seeing the same poll taken with a geographical spin.
I'm curious to know what folks do here in Georgia. I personally blow out my lines and then pump AF throughout just to be safe, but have often wondered if that's overkill for my location.
2012 Surveyor SP280
2017 Ford F-250, 6.7L Powerstroke
Equal-i-zer
10-23-2015, 09:32 AM
Broken Toe
Water is only an issue when there is no room for it to expand as ice. You could have a sealed tank 3/4 full and not have an issue when it freezes. Blowing the lines might leave drops of water here and there, but there is enough 'air-space' that it's not a problem. Once I get my compressor hooked up, I will run the water pump for a few seconds to blow out the water.
The reason I blow instead of using A/F is that my first camper was an 89 Winnebago Class A. The prior owner "winterized" it by dumping about 5 gallons of A/F in the freshwater tank, and then running all the faucets till it came out pink. Nothing ever froze, but despite NUMEROUS flushes, sanitizing and every other thing I could try, the fresh water system still had a distinctive and unpleasant A/F taste to it. To the point of having to haul bottled water around for coffee, drinking and doing dishes.
I vowed that I would never EVER use A/F in my freshwater system anywhere again. I honestly would rather replace broken lines or the pump than deal with the A/F taste again.
Tim
10-23-2015, 09:49 AM
Tim
Two things there. Not sure if the air pressure actually goes through your pump. And there's not much room in that pump. Also, you never put AF in the fresh tank. You use a valve and hose on your pump inlet to switch between the fresh water tank and a tube where you can suck AF out of the bottles. AF in the fresh water tank is a mistake.
10-23-2015, 09:54 AM
Pacific Northwest
Parked in my yard
All tanks drained
Blow out lines and HW tank
Add A/F via water pump to lines (only)
A/F down the drains to fill the traps
Remove any liquids...even dish soap
Leave nothing that would invite rodents
Remove batteries
Slides in
Heaters set to come on just above freezing
(set at - just to take the chill off and move the air)
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
10-23-2015, 10:02 AM
Voted
You don't have those U shaped pipes under you sinks? Those are to prevent the smell from you gray tanks coming back the drains for the tanks. I have never seen sinks without one but I guess it's possible.
i do both air and AF but I but probably over doing it but only takes me a few minutes to do it.
Voted
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
10-23-2015, 10:32 AM
The results are a little surprising so far. I expected the blow out with air & use AF choice to be first, and it is, but I didn't expect the AF only choice to be second.
I figured the two "air only" choices would be higher.
10-23-2015, 11:09 AM
If you use AF and have not seen my posts under "vinegar vs. ammonia" you should review.
http://www.forestriverforums.com/for...d.php?p=989794
I was surprised to learn some RV antifreeze contains methanol or ethanol! These are not compatible with the polyethylene tank (Black, Gray, & Fresh water). It makes holes in the tank!
I used an AF with ethanol once and it did leave a taste in the water stored in the FW tank. It soaks into the plastic and leached out into the stored water. The wife has required bottle water since for consumption, even though it's been three years and I can't taste it anymore.
I now make sure the RV AF doesn't contain methanol or ethanol. Most of time the labels state if it has alcohol, but all ways check the MSDS as I found one brand listed special blended inhibitor and reading the MSDS indicated the inhibitor was ethanol!
If the label states it is flammable that your sign to leave it on the shelf!
Erik Lundquist
10-23-2015, 11:19 AM
I bought this stuff from Menard's. It seems to be ok.
MSDS here.
10-23-2015, 11:29 AM
I think it was a Splash Pool/RV AF I got from Lowes the one year that contained ethanol. The pool AF always seam to have ethanol. You need to check each time as they reformulate all the time. I am finding more that advertise they are alcohol free.
It interesting they advertise this is good to -50 deg, but the MSDS indicates the freeze point at 9 deg?
Erik Lundquist
