View Poll Results: How do you winterize?
blow out lines with air, pump AF throughout 64 39.26%
only blow out lines with air, pour some AF down toliet(s) and sink(s) 36 22.09%
only blow out lines with air, don't use AF at all 5 3.07%
only use AF, don't blow out lines 54 33.13%
other 4 2.45%
Voters: 163. You may not vote on this poll
Old 10-22-2015, 02:47 PM   #1
Winterizing Poll
Just curious who does what.
Iwritecode is offline   Reply With Quote
Old 10-22-2015, 02:54 PM   #2
TURBS's Avatar
Voted!
Old 10-22-2015, 02:59 PM   #3
BendOrLarry's Avatar
We camp all winter long here in Central Oregon. I drain and then use antifreeze after every trip once we start seeing temps drop into the teens at night and not above freezing during the day.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 10-22-2015, 03:05 PM   #4
I've been using compressed air to blow out the lines and just add the pink stuff to the traps. Been doing that for the last few years with no problems.
Ontherock is offline   Reply With Quote
Old 10-22-2015, 03:11 PM   #5
thebrakeman's Avatar
I use AF only.
#1 reason is that I can winterize at the storage yard (don't have to bring camper home) only having to bring my battery. Bring the battery and LP tanks home, and I'm done. But of course, de-winterizing with AF is a process, versus nothing really to do if you only blow out with air.
To a lesser degree, I like knowing that I have removed every bit of water from the lines. It's possible for air to shoot across the top of water at a low point in the hose, leaving. There are techniques for minimizing this risk (hitting with air multiple times, etc), and I know that a small amount may not be enough to rupture a hose.
The time to run AF or to blow with air is about the same.
IMO, if you are going to run AF, blowing out with air first is a complete waste of time and energy.
thebrakeman is offline   Reply With Quote
Old 10-22-2015, 03:15 PM   #6
ColoradoRick's Avatar
Both!
I have to do both....it got down to -20 below here in Colorado last winter and I've seen a little water inside my brass sprinkler system crack it so don't want cracked lines, water heater, or water pump in the camper.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-22-2015, 03:28 PM   #7
Future Roo 23IKSS Owner
elundquist's Avatar
Winterizing Poll
I live in the mountains of Colorado, so below freezing temps are common. I blow out the system to remove slugs of water. I then pump AF into the system. The protection is the antifreeze and blowing the system quickly with air is to remove most of the water.
I only have a small twin tank job site compressor, so it can not provide enough air to clear the system of all water.
Why bother with air? To remove water from the city water connection & force water out to prevent it from diluting the antifreeze.
Erik Lundquist
iPhone 6S using Tapatalk
elundquist is offline   Reply With Quote
Old 10-22-2015, 09:49 PM   #8
Broken Toe
Cowracer's Avatar
voted. I blow (easy turbs) and use A/F in the drain trap, although i forgot one year with zero issues.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 10-22-2015, 09:57 PM   #9
Engineer of Crazy Train
ChooChooMan74's Avatar
Belt and suspenders!
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 10-22-2015, 09:59 PM   #10
mud yapster's Avatar
I just blow out the lines and drain HW tank. No pee traps in ours so no AF down drains. No issues so far in 20 plus years but we have mild winters here and us the RV year round.
Voted
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
winter, winterize
