Old 09-30-2012, 04:05 PM   #1
Winterizing Question
Just bought a 2013 Crusader 320, anybody know where the hot water heater bypass valve is located on that model?
jerryr854 is offline   Reply With Quote
Old 09-30-2012, 04:40 PM   #2
3 Happy Campers's Avatar
If you do not have a set up as shown below then you will need to access behind the water heater.
You may or may not have a bypass. I’ve had two RV that did not. Good news is there are kits @ your local RV dealer for about $15 or you can find all the parts @ HD or Lowes for about $8-$10.
Name:	Cord & Hose Brackets (2).jpg
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 09-30-2012, 05:26 PM   #3
It's located behind the bulkhead in the basement on the hot water heater side on my 2012 Crusader 320. You should see about a 10"x 10" access panel screwed onto the bulkhead ( 4 screws ).
grayfox is online now   Reply With Quote
