Old 09-14-2013, 09:41 AM   #1
Canadian Member
itat's Avatar
Winterizing - Remove Water Filter?
I'm winterizing the Roo this weekend. I just pumped antifreeze into my water lines but forgot to remove the water filter from the canister. Is there any need to remove it or can I just leave it in? I always put a brand new filter in in the Spring so I'm not concerned about reusing that filter.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 09-14-2013, 09:47 AM   #2
Witch Doctor's Avatar
I would say just leave it in if you used the bio pink stuff, shouldn't hurt anything and just replace it next season
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-14-2013, 10:36 AM   #3
rattleNsmoke's Avatar
X 2
rattleNsmoke is offline   Reply With Quote
Old 09-14-2013, 11:47 AM   #4
jimh's Avatar
agree.
last year i unscrewed the lines from the water filter and just put a nipple in between.
i have room to play with around the filter so this is an easy way to not get antifreeze in it. the rest would be to pull the element and drain the filter housing. then put a couple of caps on the open lines on each side.
Name:	water filter bypass.jpg
jimh is offline   Reply With Quote
Old 09-14-2013, 12:54 PM   #5
Steeljag's Avatar
Winterizing? The season is just starting down here.....lol....
1930 lbs CCC
2014 Jeep Rubicon JK
Steeljag is offline   Reply With Quote
Old 09-14-2013, 01:40 PM   #6
DDC
DDC's Avatar
Thats actually a tough call because whats in the filter housing may be very weak a/freeze because it would be nearly full of water as it just drops a little when you blow the lines out.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 09-14-2013, 03:11 PM   #7
Windywest's Avatar
Our manual says to remove the filter, empty the canister, then winterize. RV antifreeze will freeze, it just doesn't expand. If you have water mixed with antifreeze, you could get expansion, and your canister might break if you leave it full. I'm going to bypass my filter all together, might even take it out since we never use it and all this year never had a filter in the canister. Most campsite water is so chlorinated that it's almost impossible to drink, so we always take bottled water, and water from home for coffee and cooking.
Cheers from Alberta Canada
2011 Flagstaff 8526RLWS 5th Wheel
2011 Ford F250 4X4 Crewcab Superduty 6.7L Diesel
B&W 3300 Hitch for Ford 5th Wheel Prep package
Windywest is offline   Reply With Quote
Old 09-14-2013, 03:43 PM   #8
Another solution is to use a kit which blocks water/antifreeze from getting into the canister during winterization. The kit consists of an aluminum plate and a rubber gasket both circular which fit one on top of the other sealing the top of the canister. Bought this at our local RV supplier. I left it in all year as don't use the filter but one caution. You need to ensure the canister is tight or leak can develop.
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 09-14-2013, 05:11 PM   #9
I agree with this. The next time remove the element and place a empty( with cap on) soft drink bottle inside to take up the space,then run R/V Antifreeze thru the system. Youroo!!
Old 09-14-2013, 06:07 PM   #10
raspivey's Avatar
I accidentally left mine in on the last trailer. It plugged the filter up after sitting a few months. If you're just going to replace it, no big deal but otherwise I'd take it out.
