Old 12-22-2015, 08:31 PM   #11
Left Coast
O...KKKKaaaaayyyyyy.
Old 12-22-2015, 08:35 PM   #12
Surveyor Mike's Avatar
Merry Christmas !!!
2004 Surveyor 291 ultralite
2008 Ram 1500 quadcab Hemi
Surveyor Mike is offline   Reply With Quote
Old 12-22-2015, 08:36 PM   #13
Left Coast
Back at 'ya!!
Old 12-22-2015, 08:49 PM   #14
Ambassador
Ken K.'s Avatar
My shower has a bubble skylight. If it weren't for that I would have to duck. It's a life saver. I have to say if the weathers warm and it's allowed I have an outdoor shower set up. I use Dawn to bathe with since it breaks down so easily....
2016 Ford F250 Crew Cab 6.2 L w/Ride Rite Air Leveling System.
2017 Rockwood Signature Ultra Lite 8335BSS
Ken K. is offline   Reply With Quote
Old 12-23-2015, 05:58 AM   #15
CAT-RN's Avatar
Originally Posted by Rick-s View Post
We have a 2015 Forester 2431S class C. Questions - Do the low water drains drain the FW tank? Does the low level drains have to be closed before blowing out the lines or putting in AF? And There is a -"NOTICE Remove the waterless trap before using mechanical drain-cleaning devices. Waterless-Trap can be damaged." What does this mean and does it have any thing with winterizing?
Not sure about your unit but I think low point drains will have to be close while blowing out water lines. Close all lines then open one at a time to blow lines. If low drains are open all or lots of the air will go out low point drains. Consider low point drains just another faucet.
When adding AF same thing one valve at a time. Don't forget outside shower
Russell
CAT-RN is online now   Reply With Quote
Old 12-23-2015, 06:03 AM   #16
I dont use any AF, we just blow out lines real good, wait a few minutes and hit it with more air. Takes me about a half hour but no AF means no bad smell or taste in the spring to deal with . AF is only for my traps now.
Old 12-23-2015, 06:25 AM   #17
That's correct Russell. The low point valves need to be closed to blow out.
Karl4Cat is offline   Reply With Quote
Old 12-23-2015, 04:58 PM   #18
Appreciate all of the information but I have been under the unit and haven't found the drain for the FW tank. What am I missing. The RV is a 2015 Forester class C 2431S.
Rick-s is offline   Reply With Quote
Old 12-23-2015, 05:03 PM   #19
CAT-RN's Avatar
Know nothing about your RV. But it should be on the end of your FW tank. Probably a valve right at the tank then a short line dumping thru the floor ?
Russell.
Old 12-23-2015, 05:06 PM   #20
CAT-RN Thanks I will take another look un the unit.
fuse, winter, winterize
