Old 11-13-2018, 06:54 PM   #1
waybeck2018
waybeck2018's Avatar
Winterizing Surprise
So, being the good little RV person, heeding all advice about winterizing, I started by draining the fresh water tank and opening low point drains. Took about five minutes then watched it drain. Then started to drain the hot water heater. What a surprise! Took forever to get the plug out. I tried crescent wrenches and various sockets. WHO would ever imagine this nylon plug needed a 1 15/16 socket?? Certainly not me. Obviously. When I finally got the plug ot no water flowed from the tank. Any ideas on why?
waybeck2018 is offline   Reply With Quote
Old 11-13-2018, 06:56 PM   #2
cavie's Avatar
Did you open the temp pressure relief valve?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 11-13-2018, 06:58 PM   #3
A32Deuce's Avatar
You did not do the winterizing valves behind the heater before opening the low point drain. Only problem with doing that is calcium from inside the tank can/will,get into your lines and cause water flow troubles.
A32Deuce is offline   Reply With Quote
Old 11-13-2018, 07:00 PM   #4
PPST Wannabe
kenandterry's Avatar
Because you mentioned it has a nylon plug, that pretty well guarantees you have an Atwood water heater.......Suburban units have a metal anode to drain the tank and have a 1 1/16 head.
Did you release the pressure in the water system by opening the taps?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-13-2018, 07:02 PM   #5
waybeck2018
I did open the relief valve. I saw no way to open/close any other valves and could not find a by-pass valve. Off to the dealer to show me I guess.
Old 11-13-2018, 07:03 PM   #6
waybeck2018
I did open all taps, shower and all sinks.
Old 11-13-2018, 07:03 PM   #7
A32Deuce's Avatar
Opening the low point drain will empty the tank.
Old 11-13-2018, 07:06 PM   #8
waybeck2018
Behind the heater? That means getting inside and finding access to the heater. New rig for me, so now I will find the tank access. Fortunately temps have remained in the 40/50 degree range this week.
Old 11-13-2018, 09:27 PM   #9
A32Deuce's Avatar
Maybe you should tell,everyone what you have. Make, model, year. Then someone would be able to tell you where to look.
Old 11-13-2018, 09:29 PM   #10
waybeck2018
A32 duece, thanks for the suggestion. I have a 2019 Prime Time Tracer, 34 ft
winter
