Old 11-02-2012, 09:06 PM   #11
dsotmoon's Avatar
Originally Posted by DeRosa2013 View Post
Turn the valve on the water pump to bypass its use and to enable the antifreeze pickup port to be used.
I just want to make sure, do I turn this knob so that it faces straight up to pull from the winterizing outlet?
Joe
Salem, VA
2011 Dodge Ram
2013 Rockwood 8319SS
dsotmoon is offline   Reply With Quote
Old 11-02-2012, 09:18 PM   #12
Old car's Avatar
Not knowing all your plumbing and how it flows I don't want to give you bad information. The handle should be in line with the hose for it to flow and to block off the line--the handle should be perpendicular to the hose. Line from fresh water tank should be blocked off so it looks like your valve handle needs to be turned 90 degrees.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 11-13-2012, 05:58 PM   #13
dsotmoon's Avatar
Just fyi for anyone with the same set up and wondering as I did, I winterized this past weekend, turned the valve in the pic above straight up position, closed the water heater bypass, turned on the water pump, connected the antifreeze to the winterizing inlet on the outside and pumped right in, perfect, easy, fast
i imagine now that i know where all the valves are, winterizing can be done in about 30 minutes max
Joe
Salem, VA
2011 Dodge Ram
Old 11-15-2012, 11:16 AM   #14
HONDAMAN174's Avatar
Is the socket size for the water heater anode 1 1/16th?
Need to grab one today
Just glad to get away
Old 11-15-2012, 11:21 AM   #15
Yes,6PT. Youroo!!
Old 11-15-2012, 11:30 AM   #16
Originally Posted by youroo
Yes,6PT. Youroo!!
Thanks. Hello harbor freight!
Headed to Williams,AZ for thanksgiving and will probably be parked until Christmas after that so might as well blow out the lines until needed again.
