10-06-2016, 08:49 PM
code.org
Winterizing water heater with vinegar
I found this video on YouTube describing how to remove the deposits in a Suburban water heater using vinegar when winterizing an RV.
Has anyone done this and is there any potential for harming the water heater?
Randy, Mary, and Mojo
Rockwood Signature UltraLite 8329SS
2001 Dodge Ram 2500 Cummins Diesel / Allison Trans
2015-14 Nights, '16-90 Nights, '17-101 Nights, '18-146 Nights, '19-76 Nights '20-56 Nights '21-42 Nights '22-86 Nights '23-65 Nights
10-06-2016, 08:59 PM
I will be doing this in about a month. Same principal as descaling your coffee maker. Viniger gets rid of the scale and calcium deposits.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
10-06-2016, 09:06 PM
My only comment is no teflon tape on the anode rod threads. You want conductivity between the threads of the rod boss and the tank itself at all times. I use a little bit of copper never seize which is conductive, on the threads.
Acetic acid will dissolve lime scale and you can buy acetic acid liquid and not use white vinegar.
If you want an inexpensive bore scope to look inside, Harbor Freight has them for 50 bucks everyday. I have one, very useful tool.
10-06-2016, 09:08 PM
After the vinegar flush, drain the heater and leave the anode out with the T&P valve open and the heater in bypass...if you store the RV.
10-06-2016, 09:38 PM
You'll still have conductivity with the teflon tape. It gets cut by the treads. It does not provide total isolation.
2011 Traverse LT, 3.6L, FWD
10-06-2016, 10:10 PM
Agree, just test with meter for conductivity between head of anode and case of heater reading close to 0 is good.
10-06-2016, 10:29 PM
True, and Suburban as well as Camco states to use teflon tape for their anode rods. Some anodes come with the threads pre-wrapped.
Here is a link to a previous discussion on this:
http://www.forestriverforums.com/for...ape-98520.html
Whatever you use, you should be sure it is safe for potable water use.
2011 Flagstaff 831 RLBSS
10-07-2016, 02:36 PM
As soon as my Suburban water heater bites the dust, I am getting an Atwood. Glass lined and does not need an anode.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
10-07-2016, 02:38 PM
I think it's because the Atwoods are aluminum is the reason for no anode.
10-07-2016, 07:27 PM
I have an instant hot water heater for my home and once a year I flush the system with vinegar.
I use a submersible water pump and attach a 2 hoses to the in and out outlets. I run the pump with vinegar for an
Hour then flush with water.
This process should be able to flush the lime deposits in my wh..
