Old 01-23-2013, 06:34 PM   #41
Herk7769's Avatar
Originally Posted by mm29 View Post
I cant get the plug out of the hot water heater. I bought the 1/2 ratchet with the 1/16 bit but I cant manuever the ratchet into the heater, not enough room. Its to long. Any ideas?
I use a short (3 inch) 1/2 inch extension for the 1 1/16th inch socket.
Craftsman 3 pc. Extension Bar Set, 1/2 in. Dr. - Tools - Ratchets & Sockets - Socket Accessories
HAM CALLSIGN - KC3FFW
Old 01-23-2013, 06:45 PM   #42
I have always blown my system out with air similar to what you describe and add anti freeze to the traps and toilet. A couple places that can be problems are the toilet valve and shower head. I always double check them. This method has worked for me in Wyoming where we can see 20 to 30 below zero at least once every winter!
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 01-23-2013, 06:49 PM   #43
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
Oookay so I DID turn the HW bypass
....I could not get any pink fluid to come out of the hot water faucets...
Hope I don't have a problem come spring or the next time I go camping.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight & Valor
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 01-23-2013, 07:18 PM   #44
Herk7769's Avatar
My guess is the valves was rotated in the wrong direction and the hot water is being shut off and not bypassed.
If the two lower valves are closed, there will be no hot water going to the hot water faucets. To get RV antifreeze to flow to the hot water taps the upper and lower valves must be closed and the middle valve OPEN.
Old 01-23-2013, 07:38 PM   #45
racedaymechanic's Avatar
Umm, an extension??
2009 Sabre Palomino "Sissy"
1998 Chevrolet K3500 6.5 Diesel "Brutus"
racedaymechanic is offline   Reply With Quote
Old 01-23-2013, 07:56 PM   #46
Thank you
mm29 is offline   Reply With Quote
Old 01-23-2013, 07:59 PM   #47
itch'n to road trip
campnqueen's Avatar
Dang Herk! Just what i thought! You are good!
Jasper Ga.
Old 01-23-2013, 08:10 PM   #48
flyrotor's Avatar
Use a 4" or 6" extension to the ratchet, this will allow you to reach the plug.
flyrotor is offline   Reply With Quote
Old 02-25-2013, 09:14 PM   #49
I personally like to avoid chemicals when my body and food comes into contact with the water and even more important if you are drinking the water! Blow the lines out but add antifreeze to your waste tanks by pouring down all drains. It is a reliable and completely appropriate way of winterizing. Most importantly, however, is to do what helps you to sleep at night. There are two ways of winterizing. People have their preferences but blowing out your lines and flushing antifreeze through the system sounds like overkill.
MichelleCRNA is offline   Reply With Quote
Old 02-27-2013, 02:18 PM   #50
dretired's Avatar
small amount of water NOT blown out can and will cause damage..i would not want to drink rv anti-freeze either ...flush out everything and dont drink the water.. if... you dont trust it being safe
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
