Old 03-18-2013, 06:47 AM   #1
Would this work to blow out water lines
Dealer winterized in the fall. Then de-winterized last week prior to a trip to Disney for Spring Break. Now getting a cold snap (20 degree night) this week.
Planning to drain water heater, blow out the lines, & add anti-freeze to drains.
Don't have an air compressor. Do have a Black & Decker air station (see link below). Would this work to blow out water lines?
Thanks!
Black & Decker ASI300 Air Station Inflator - Electric Air Compressor - Amazon.com
paulmlac is offline   Reply With Quote
Old 03-18-2013, 06:53 AM   #2
TURBS's Avatar
I don't see why not.
Turbs
Old 03-18-2013, 06:55 AM   #3
Would have to think if u fill an air tank that u can buy at harbor fright u should be able to have some air to blow out the lines. Bought mine there for like $20.00.
Hope this helps
Sam2581
sam2581 is offline   Reply With Quote
Old 03-18-2013, 07:05 AM   #4
MtnGuy's Avatar
Does it have a regulated air supply ?? You definitely don't want full pressure in your water lines.
I just use a bicycle pump, even though I have an air compressor. I don't like the looks of the condensate that comes out of my air compressor, and don't want any residue in my water lines.
Old 03-18-2013, 07:09 AM   #5
TURBS's Avatar
Don't really need more than 20lbs regulated pressure.
Old 03-18-2013, 07:10 AM   #6
Yes u can put a valve on it and only let a little or a lot of air out. U don't want to use to much u could blow out a line . Best of luck
Old 03-18-2013, 08:34 AM   #7
I bought an air compressor at Sears this morning.
Was the least expensive one they had. Normally $80. On sale for $60. I had a $5 coupon. Plus a little over $30 in gift cards. So I paid only about $25.
Hopefully it works for what I need. Only two uses really. Winterizing per my post above. Also figure it will fill up the rig's tires quicker than the Black & Decker Air Station I linked above.
Saw some reviews for it after I left the store. A mixed bag. Time will tell.
Thanks all for the posts!
2 Gallon Air Compressor: Takes Power and Pressure to GoSears
Old 03-18-2013, 08:48 AM   #8
grege's Avatar
I was going to say post where you live and another member in the area might loan you a compressor.
'12 Ford F150 Lariat Super Crew
'17 Grand Design Imagine 2800BH (Previous '13 Roo 21SS)
2016 Nights camped: 7
2015 Nights camped: 21
2014 Nights camped: 18
2013 Nights camped: 26
grege is offline   Reply With Quote
Old 03-18-2013, 09:25 AM   #9
Dave_Monica's Avatar
Thanks!
Those style are high pressure, low volume compressors without a tank. They're fine for inflating tires if you got 10 or 15 minutes but won't work very well to blow out the water lines on your camper.
A compressor with a tank and regulated output is what you need.
Dave
Old 03-18-2013, 04:07 PM   #10
Grape Escape
You can always blow lines out or vacuum them out with a shop vac. Worked on my inground pool for 20 years and never had a problem. Lots more air capacity too.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
