Old 05-01-2012, 11:20 AM   #1
Steve Jackson
sideout1961's Avatar
Y-Connector
Does anyone have the Y-Connector for the Rhino Hose? I just ordered one and realize that the connection to the Y doesn't match the end of the hose. It looks like I need the same fitting that is at the camper end to attach it to the Y. I can't seem to find this fitting anywhere unless I'm missing something. Any help would be appreciated.
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 05-01-2012, 11:26 PM   #2
Don't know for sure about the Rhino hose, don't know what is different about it. Most sewer hoses are 3 inches, and that's about it. They use a bayonet fitting on the end at the camper, and various elbows/adapters on the other. Camping world would be a place to check online, as they sell the Rhino hose. Since you just ordered one, might check with who you ordered from.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-01-2012, 11:32 PM   #3
Rebel702's Avatar
Look here for the connector.
Amazon.com: Camco 39783 RhinoFLEX RV Bayonet Fitting with Locking Ring: Automotive
Rockwood Windjammer 3002W (11/10/2011)
2011 Sierra Denali HD - Duramax/Allison
EQ-4, 14,000/1,400
2006 Yukon Denali
Rebel702 is offline   Reply With Quote
Old 05-02-2012, 04:45 AM   #4
Steve Jackson
Thanks Rebel, that's just what I was looking for. I ordered the Y from amazon but couldn't find this adapter.
Old 05-02-2012, 06:25 AM   #5
caper's Avatar
I have the "Y" connector and it already had the pins needed to attach the hose. There is also a "Y" with out the pins that is used for hoses that are clamped on with the metal hose clamps.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 05-02-2012, 06:44 AM   #6
Steve Jackson
Caper, are you saying that I don't need the adapter that Rebel listed? The picture of the Y looks like it needs the bayonet connector unless I'm not seeing something.
Amazon.com: Camco 39812 RhinoFLEX RV Wye: Automotive
Old 05-02-2012, 07:49 AM   #7
camper_Lucy's Avatar
Sideout1961, you will need that Y for a Rhino hose, and you will also need the 5' extension to get the elbow to the ground connector on between the Y and the end.
Amazon.com: Camco 39765 RhinoFLEX 5' RV Sewer Hose Extension Kit with Coupler: Automotive
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 05-02-2012, 08:11 AM   #8
Steve Jackson
Boy this is really getting expensive with all these adapters. All I want to do is get both my sewer and galley tank into the same hole so I don't have to keep moving the hose. My galley outlet is under my slide and a pain to get to.
Old 05-02-2012, 08:23 AM   #9
Have you considered just piping them together behind the release valve and then you will only need one flexible hose?
Pullrite 20.5K
2012 Sierra 365SAQ
Old 05-02-2012, 08:27 AM   #10
caper's Avatar
Is this the style you have purchased? It is the type I have. You do not need any extra hose the "Y" will attach directly to the fitting at the sewer end. I have the same set up with my galley under the slide out.
Terry and Janet
2007 Ford F150
