Old 07-27-2013, 07:34 PM   #1
08 v-lite converter
think mines dead, not charging the battery, I checked getting 120 to converter but only 12.08 going out which I guess is the battery voltage. I also noticed the fan not running so guess that destroyed the converter. so do I buy another main board or switch it over to another brand?
p.s. I also checked and clean the ground wire.
2008 v-lite 30 wrls
gsbuick65 is offline   Reply With Quote
Old 07-27-2013, 10:45 PM   #2
Denver, CO
garbonz's Avatar
you may just try an external 3 step charger and see if that solves the problem, and think about another converter. The Progressive Industries units are recommended by many and you can replace just the converter section of your existing unit, even if it is part of the main box by changing the wiring slightly.
In my C-cross the Converter is separate and behind the main box so it is easy to do, but in some units the converters are integral to the distribution panel. Either way it can be done fairly easily.
In the meantime you can use an external charger to keep the battery charged up.
2017 Fuse 23T
converter, v-lite
