Old 03-22-2015, 06:18 PM   #1
1000w vs 2000w vs solar
We have a Shamrock 19 ft Hybrid. We use the batteries for water and heat only. We camp in the Smokys in early November and early May. Last November we had a few nights below 20 degrees. The batteries (2-12's) lasted 2 nights. Would the Honda 1000 watt generator, with the Trailer plugged in, charge the batteries so we won't run out of electric or should I get the 2000 watt? Would a solar set up be able to accomplish the needed recharge?
jrctoby is offline   Reply With Quote
Old 03-22-2015, 06:59 PM   #2
1000 wW generator plugged in to a decent battery charger will do fine.
donniedu is offline   Reply With Quote
Old 03-22-2015, 07:09 PM   #3
Blackhat6mike's Avatar
I installed solar and haven't seen my bats below 12.7 since and I run a lot of 12vdc stuff. Your bats need to be large [115 amp hr or above] and deep cycle. No storage, no power. Small bats won't hold enough juice.
As far as which gen to get, always go bigger.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-22-2015, 07:10 PM   #4
Related question: the owner's manual describes the converter on my 2014 21DK as having a 3-stage charger. That being the case, do I need to bring my Schumaker charging and plug it directly into the generator? Out is the on-board charger sufficient, if I plug my generator directly into the 30A feed?
Sent from my phone using Tapatalk.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 03-22-2015, 07:20 PM   #5
Personally I would look at the input amps of your battery charger and size a generator to that. Feeding through the converter will draw a lot of amps.
Old 03-22-2015, 07:31 PM   #6
RPAspey's Avatar
Which charger/converter has the higher DC output? I'd go with that one as it would decrease the time it takes to charge the batteries. If you use the Schumacher, turn off the converter.
Personally, I'd go big on the generator as I would use it for other things. But the 1000 watts is plenty to charge the batteries...no microwave, coffee pot or hairdryer, etc though. And the 1000 watts is lighter and sips fuel.
At a 10:1 ratio 12v DC current to 120v AC current, you'd have well over 70 amps available to charge the batteries on the 1000 watt genny. Assuming 100% efficiency and no other loads.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-22-2015, 10:56 PM   #7
Your three stage converter/charge should be fine to charge your batteries. Now if you have 6v GC2 golf cart batteries that is another can of worms. I just bought some and am researching how to properly charge them. They take 15.3v of absorption charge which no ordinary charge supplies.
FR Stealth 2313
Chevy 2500HD Duramax
hammick is offline   Reply With Quote
Old 03-22-2015, 11:14 PM   #8
SKnight's Avatar
Get the 2000, it's not too much more money than the 1000, is still very fuel efficient, still very quiet, can run more (microwave, coffee maker, etc.) and can be paralleled in the future to run your AC.
Old 03-23-2015, 07:41 AM   #9
Herk7769's Avatar
TIP: Buy the Companion Model FIRST. It comes with everything you need to parallel (except the connecting cables - which you SHOULD buy when you can).
That way if you get trapped without power and need the AC, finding a standard one in stock is a heck of a lot easier than finding the Companion on the shelf!
HAM CALLSIGN - KC3FFW
Old 03-23-2015, 02:01 PM   #10
TGR
TGR's Avatar
Just a reminder, a 1000W generator will charge a battery through your converter or an external battery charger just as fast as a 2000W generator. It will take several hours of running the generator to charge the battery and most battery chargers are not as good as the RV's converter for charging batteries. Going below 50% charge on a battery does reduce its useful life but sometimes that is necessary.
I prefer the larger generator because I can run a toaster, coffee pot or microwave, only one at a time, and it will run all night for the furnace no matter how much the furnace runs. I have a pair of 2000W Yamaha generators so I can run the A/C when needed but so far I've only used one generator at a time.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
solar
