Originally Posted by Bama Rambler
There should be an SO (extension cord looking) cable ran in the wire support and loom going from the main body into the slide. It should be at one side of the slide. If you can find that, you should be able to reconnect it and have the receptacle back working.
X2
For flexibility of running the slide in and out, manufacturers use SO service cord (sometimes SOOW or SJOW) in the flex arm bracket and then connect it to an inside junction (near the outlet) to a short piece of Romex that terminates at the the wall outlet.
You'll need to see what all is missing. Maybe even the flex arm?
