Old 11-22-2018, 06:18 PM   #21
Yes but resetting breaker isn't fixing the problem.
KristenW is offline   Reply With Quote
Old 11-22-2018, 06:19 PM   #22
We have cycled all of them
Old 11-22-2018, 06:29 PM   #23
If you have done what we told you, get a multi-meter and start at the circuit breaker box. Check for voltage at all breakers. one of the will feed the GFI outlet. If the GFI outlet has no power the problem is in in the breaker box or in between it and the GFI outlet. It is a very small trailer. Should not take long to find the problem.
Old 11-22-2018, 06:59 PM   #24
Ha,will take me longer to find a multimeter... although maybe not with the amount of stuff some of these people have at their sites...potted plants?!? Thanks for the help, maybe can do that tomorrow.
Old 11-22-2018, 08:12 PM   #25
Guys guys guys! There was a breaker on the inverter that had to be reset in order for the GFCI outlet to be able to be reset. Even though I could push the inverter power button and IT came on, that breaker i guess must be required to pass power to outlets even though I'm plugged in. And if you're like, hmmm, where's my inverter, on the 19fd it is in the front left compartment behind flimsy panels that are screwed in place and have to be removed to get to this tiny little breaker on the bottom. Thanks to the help from y'all and a thread on another forum, my coffee will be inside in the morning! Woohoo! Happy Thanksgiving.
Old 11-22-2018, 08:15 PM   #26
Good on you!
Thanks for coming back with the fix.
Definitive fixes always help someone else somewhere down the road.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
110v
