08-06-2016, 10:41 PM
'11 390BH
110V system partially dead
Its full day #1of a 14 day trip with the wife and kids....My wife was using a hairdryer in the bedroom of our 2011 390BH Berkshire, and the circuit went dead, i was showering so i heard only her complaint.
The tv, bunk, and bed area outlets all went dead. None of these effected circuits wear a "part of a gfci circuit" sticker on them. All of the other outlets, except the microwave and washer (also unaffected) have gfci stickers on them and they all work.
I reset both the bath and kitchen gfi outlets first anyhow, then went to looking at the ac breakers. Nothing was tripped, so panel cover off and multimeter out....all of the circuits were properly passing full voltage through the breaker.
Ive looked at the manual and I've covered the locations noted there, So does anyone know of a third gfci outlet location? Or a second AC breaker panel, or trick etc to try and restore power to the back half of my coach?
Every neighborhood has one...in mine, I'm him!
08-07-2016, 06:31 AM
Look outside.
You may have an outside outlet, and you may also have one in the frig compartment.
On your GFCIs, press the TEST button, then reset it.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
08-07-2016, 08:21 AM
'11 390BH
Yeah that was my thoughts also. Shame i cant find it. Everything outside has power
08-07-2016, 08:29 AM
You might want to remove the outlet and see if the wires are loose on the outlet.
08-07-2016, 08:39 AM
Check your AC breakers again in panel....a trip breaker might not look tripped and needs to be reset: usually to the right then closed to the left.....
Fonzie
08-07-2016, 10:35 AM
'11 390BH
All good advise. I tried the breakers, reset all of them yesterday. I have not removed the outlet yet though, worth a look but i doubt thats the issue because outlets on both sides of it are dead also.
Keep it coming please!
08-07-2016, 10:59 AM
You will prolly be disappointed when you pull the outlet. It most likely will have push in wire connectors. I think you need a tool to re-crimp the outlet if salvageable. I was going to replace an outlet with a usb charging outlet. I found no box and wires crimped in. Had to regroup and get a remodelers box to fix. I hope you find/fix easily.
2017 Puma 297RLSS
08-07-2016, 02:29 PM
Just A Member
If you are 50 amp service reset the breaker at the service stand.
2013 Forest River Flagstaff
2018 GMC Sierra 2500 HD Duramax
08-07-2016, 02:45 PM
I say BINGO...
Coachmen M/H
Concord
2018 / 300 DSC
08-07-2016, 02:51 PM
GFI The curse of electric wporld
My hair dryer has GFI built into the plug. Just a thought. Have power at the outlet? Buy a cheap 3 light plug in tester and keep in TT. Some even have a GFI tester built in.
08-07-2016, 03:06 PM
Like Iwannacamp said about the plug outlet , on my 3051s the outlet in the fridge compartment crapped out and left half the MH without power. What had happened was the cheap outlets are the speed box design where the wire is just pushed into a V shape connector and it had worked its way loose and melted the connection, causing a open neutral reading on my tester. Try and work your way back from the last plug that doesn't work to where the power is picked up from the control panel and check that outlet. Good luck.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
08-07-2016, 03:10 PM
Here is pic of where outlet had melted
2014 Forester 3051s
2012 Sonic toad
08-07-2016, 03:29 PM
'11 390BH
I want to thank everyone for the good suggestions my troubleshooting flow followed most of yours. I did finally figure it out without any more dissasembly.
The problem all along behaved like a tripped breaker or GFI. But as I described I was not finding an issue there after checking with a mm.
What it turned out to be was all of these outlets are on the inverter, which means power flows to them through the inverter..... and we had tripped the breaker on board the inverter! You can see it in the picture as ac out Problem solved and lesson learned
08-07-2016, 03:38 PM
Glad you found it an reported back....
Fonzie
