Old 07-21-2016, 04:17 PM   #41
Originally Posted by Kenny kustom View Post
Actually it is.
Go check out some large solar installations.
Even better. Look at some high current setups.
You will find we are correct.
That is the same as option 2 of the OP's post, the correct way to balance a bank that I was referring to. You were agreeing with spock123 that option 1 was the correct way.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
Old 07-21-2016, 04:28 PM   #42
Kenny kustom's Avatar
12 V Battery Connection
Just keep winking...
Anyways. You keep you batteries wired one way.
We will keep ours the better way.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-21-2016, 04:34 PM   #43
Originally Posted by boondocking View Post
Really not the most efficient way for a balanced bank.
How do you figure, drawing of the single battery is balanced?
Let's see your battery bank?
2016 Sabre 36QBOK
Old 07-21-2016, 04:44 PM   #44
If you want to get really fancy.
This one goes as far as equal length cables.
Even on my two battery setup, I tried to be as equal length as possible. Attachment 114274
2016 Sabre 36QBOK
Some how you are confused. The example you gave is the same as option 2 of the original OP. Which is what I am referring to.
2007 Surveyor SV230
Old 07-21-2016, 05:02 PM   #45
2016 Sabre 36QBOK
My bank correctly balanced.
2007 Surveyor SV230
Old 07-21-2016, 05:09 PM   #46
Attachment 114863
Right on!
I'm saying. Have the draw feed one off each battery.
I've said that all along!! 👍🏻👍🏻
2016 Sabre 36QBOK
Old 07-21-2016, 05:26 PM   #47
Originally Posted by spock123 View Post
To each his own, I'm not trying to change anyone's mind but I'll keep wiring my batteries like option 1.
Agreed... The correct way.
2016 Sabre 36QBOK
The above agreement by you is where the confusion came in.
Option 1 that spock123 is referring to is connecting the pos cable and neg cable to same battery.
2007 Surveyor SV230
Old 07-21-2016, 05:33 PM   #48
Originally Posted by chideock View Post
I am asking which of the diagrams below is the correct way to connect two 12volt batteries in my motorhome? Or does it matter?
First diagram shows how the batteries in the old motorhome were connected.
Second shows how my new motorhome batteries are connected.
Look option one is like ours.
2016 Sabre 36QBOK
Old 07-21-2016, 05:34 PM   #49
That's option two...😜
2016 Sabre 36QBOK
Old 07-21-2016, 06:56 PM   #50
That's option two...��
2016 Sabre 36QBOK
LOL
I'm not sure what you are looking at? The second image (option 2) shows the neg cable (ground) connected to battery #1 and the pos cable (power) connected to battery #2.
Unless the images are reversed on my monitor the top one (option 1) shows the neg (ground) and the pos (power) connected to the same battery.
Oh well, it's all good !
2007 Surveyor SV230
battery
