Old 07-16-2016, 03:59 PM   #1
chideock's Avatar
12 V Battery Connection
I am asking which of the diagrams below is the correct way to connect two 12volt batteries in my motorhome? Or does it matter?
First diagram shows how the batteries in the old motorhome were connected.
Second shows how my new motorhome batteries are connected.
2016 Sunseeker 3010ds towing a 2013 Ford Explorer 3.5L AWD.
chideock is offline   Reply With Quote
Old 07-16-2016, 04:18 PM   #2
fonzie's Avatar
#2 is best
Fonzie
Old 07-16-2016, 04:23 PM   #3
SeaDog's Avatar
X2 with #2
Retired Navy
2016 Flagstaff 26 FKWS
Old 07-16-2016, 04:29 PM   #4
x3 for second connection.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 07-16-2016, 04:34 PM   #5
Kenny kustom's Avatar
First connection will draw equally though both batteries.
Both will work. First one works better.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 07-16-2016, 04:44 PM   #6
BandJCarm's Avatar
Well, I flunked the Smarty Pants thread...........so I probably will expose more ignorance here.......
But, other than the pictures and the batteries are turned 90 degrees from each other, what is the difference? Both are wired in parallel. The only true difference I see is that in #1 the neg goes to neg on the source, and in #2, the neg goes to a ground.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-16-2016, 04:46 PM   #7
raspivey's Avatar
Honestly, you shouldn't see any difference at all. You're not really "pulling" through one battery into another as you would with a series connection. You're just tying posts together and drawing from both at the same time. One battery may be slightly less efficient, but that will be due to the resistance in the wire between the two, which will be negligible.
Old 07-16-2016, 04:48 PM   #8
Basically the batteries are joined.
Pos is hooked to one battery, neg to the other. That way current is drawn through both.
It matters more during high current/load situations, but if you can do it correctly, why not?
2016 Sabre 36QBOK
Old 07-16-2016, 04:51 PM   #9
If you want to get really fancy.
This one goes as far as equal length cables.
Even on my two battery setup, I tried to be as equal length as possible. Click image for larger version
Name:	ImageUploadedByForest River Forums1468705883.290728.jpg
2016 Sabre 36QBOK
Old 07-16-2016, 04:51 PM   #10
Flybob's Avatar
Slightly OT, but more important than which method you choose is that the batteries be of same type, equal capacity and very close in age.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-16-2016, 04:53 PM   #11
raspivey's Avatar
I had to look twice. The only difference is whether the wires are connected to the same battery or pos to one battery and neg to the other. Before I went to 6V, I tied my 12's together pos on one, neg on the other...mainly because that's what matched up to my cable lengths the easiest. Out of habit, I charge mine like that. I really don't think it makes much difference unless we're talking a LARGE battery bank. In that case, in would probably be best to wire them on opposite corners.
Old 07-16-2016, 04:55 PM   #12
BandJCarm's Avatar
Ah.
I had to look three times.
But again.........I flunked the Smarty Pants thread........so......................
FROG AR-0019-242
Old 07-16-2016, 05:16 PM   #13
Correct! Down to the same lot number!
2016 Sabre 36QBOK
Old 07-16-2016, 05:18 PM   #14
chideock's Avatar
Thanks for the answers. The two sets of batteries were/are matched pairs. Fancy is interesting but I was just interested to know if one way is better than the other. It seems from the responses that there is no better one way or the other. The batteries are in parallel and that is what matters.
Thanks all
Old 07-16-2016, 05:22 PM   #15
Thanks all
Well, technically one way is better than the other.
Will you ever notice? Nope.
2016 Sabre 36QBOK
Old 07-17-2016, 03:47 PM   #16
ELectrically, they are identical, no difference in current or draw. Whichever is easier to wire for your rig. Batteries should be same age and amperage, as stated above.
jjuscg is offline   Reply With Quote
Old 07-18-2016, 06:44 AM   #17
Wolverine 1945's Avatar
I am guessing to truly test each battery,,, I must remove both crossovers ???
Wolverine 1945 is offline   Reply With Quote
Old 07-18-2016, 06:57 AM   #18
Electrically, the two hookup schemes appear identical but aren't. The difference is the resistance of the wires connecting the two batteries together in your first hookup picture. When supplying current to loads, the battery furthest away from the load wires will supply less of the current than the one nearer to the load wires. The same logic applies to charging with the batteries closest to the load wires getting charged first.
The larger the wires between the batteries, the smaller this effect will be. The smaller the load or charging current on the batteries, the smaller the effect will be. If the load wires are hooked up as shown in your second picture, the cable lengths to both batteries will be equal and the batteries will always be drawn on and charged equally.
The only thing in an RV that would make the battery hookup configuration critical is an inverter. Newer RVs with a residential fridge will have one of these which will place a large enough draw on the batteries to make having the optimum hookup a more important factor for full battery life.
As an FYI, my knowledge in this area comes from research and installation of a 10KW battery bank to run an off-grid solar/wind powered observatory.
Phil
pmsherman is offline   Reply With Quote
Old 07-18-2016, 07:21 AM   #19
waiter21's Avatar
I'm not sure I see any difference?????
Either connection will be acceptable...
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 07-18-2016, 07:22 AM   #20
Bingo!
If all wires are of similar gauge and length, in a TWO battery, parallel set-up, you will see a negligible difference between the two proposed connections. This is of course, dependent on the two batteries sitting next to each other. If one is at one end of the rig and one at the other... all bets are off on either one of the connections.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
battery
